Question about Jensen VM9410 Car DVD Player
Jensen dvd player opening and closing problems
My jensen dvd player will not open by itself, I have to help it in and out. When I push the open button, It starts clicking and barely moves. Same when I push to close. When I was at the local circuit city, I messed with some of thiers, and I noticed that there are a few set of gears in there. I was thinking that these gears might be stripped of even just a little off. can you give me some advice.
SOURCE: Jensen VM9410 problem
two things might be wrong is there 12 volts and is there a good ground . hope this might help.
Posted on Jan 07, 2006
SOURCE: Jensen VM9410 DVD/CD Car Player
check the amp wires i tink u got the antenna wire in the amp that way when u change to the cd player the power shut off
Posted on May 17, 2007
SOURCE: volume resets to 26 every time unit powers on
You can change the start-up volume level by doing the following: 1. Turn the volume onto the desired level 2. Before the yellow volume meter disappears, hold the audio for two seconds and you should hear a beep. 3. Check it by turning off the car and turning it back on again P.S. - You can download the manual from audiovox.com
Posted on Oct 05, 2007
backinblack
  • 11 Answers
SOURCE: monitor wont come out
I have the exact same problem on mine. If yours is like mine, It clicks a little when it tries to open and close. If that is the case, The gears that open the dvd player might be stripped or just need to be adjusted.
Posted on Feb 22, 2008
SOURCE: jensen player
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
Posted on May 05, 2009
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
Close dvd drive
Most DVD/CD drive are belt engaged driven by a small motor. If the tray is not sliding in and out by itself, it is highly probable that the belt is cut and therefore of course would require replacement. In some instances, it could be the small motor itself or the servo electronics that control it. There are also known instances when the tray is misaligned or the plastic rail/gear underneath have been worn out.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 19, 2008 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
Tray will not stay closed
This fault usually happens if the disc being read is not compatible with the player's firmware.
If discs are burnt from a computer, or copies, this can happen.
Does it do this with all DVD's?
Are you using commercial retail DVD's?
Otherwise something else is telling the player 'No Disk'.
Try a disc-based lens cleaner as laser may be grubby.
Or the laser diode could be defective.
Nov 21, 2017 | GoVideo D645 DVD Player
Jensen VM9311TS
try pressing the reset button.
Sep 07, 2008 | Jensen's VM9312 Car DVD Player
Remote control problems
Replace your battery in the remote. Dont leave something sitting on the remote that is pressing a button down, or it will drain your battery
Jul 06, 2008 | Jensen VM9020TS Car DVD Player
Wont turn on
My only suggestion as last desperation, take your dvd player out of the vehicle. Open your hood, Take the yellow, red, and orange wire, tie them together and hook it to the positive post, and black to the negative. If your dvd player comes on like it should, Then it prolly a problem in your cars computer. Some newer cars automatially disable their radios when an alarm goes off, for theft reasons.
Jan 16, 2008 | Jensen VM9410 Car DVD Player
Monitor wont come out
Dec 25, 2007 | Jensen VM9410 Car DVD Player
Tray opens / closes on its own and will not play
Your open/close button might be stuck, you can try and unplug it and spray it with silicone lubricant and push it over and over again for a couple of minutes and then turning it back on after about 30minutes so the lubricant dries down first.
If all else fails, have a local appliance technician take a look at it...
Dec 09, 2007 | Hitachi DV-P323U DVD Player
Jensen MVB85 A8.5 dvd player
Problem: All DVDs would not play in Jensen MVB85A overhead 8.5 DVD player. Error code: "Incorrect Region Code"
FIX:
1. Use the remote to power on DVD player
2. Ensure there are NO DVDs in the drive
3. When you see the DVD logo screen, press 9653 on the remote
4. A hidden menu will open stating the region code. My region code was set to 0 and my I was receiving the error.
5. Press the "OK" button to change the Region Code to "1".
Once the region code was set to 1 all DVDs were playing.
Key words: Jensen Audiovox MVB85 incorrect region code
Nov 13, 2007 | Jensen 8.5'' Overhead DVD Player Package...
Monitor won't come out
i have the same problem but i lost my remote so i cant even get my monitor to stay it just opens and close real slow can someone help
Oct 28, 2007 | Jensen VM9410 Car DVD Player
Jensen VM9410 Car DVD Player Logo
53 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
