Question about Fusion Digital designs PP-AM8004 Car Audio Amplifier
10 inch fusion amp
How do you wire a 10" 600w fusion amp
  • 4 Answers
First of all your question is unclear, do you need speaker advise or amplifier advise
Posted on Feb 23, 2008
I need to know how to hook up an alpine v12 amp 2 ohm i have two tens
This really depends if your 10" subs are 4 ohms each or 2 ohm - for this exercise, I'm presuming they are 4 ohm each.
You already know your amp can deliver 600W RMS (@ 2ohm), so you need to be careful you do not exceed the maximum RMS input power of your subs.
Normally you would wire subs in "parallel", which would reduce the circuit load to 2ohms - however, the 600W RMS power may be too high for your subs to handle.
In this case, it may be safer to wire your subs in "series" - this will increase the circuit load to 8ohms, which will effectively decrease the amps RMS power output.
Cheers,
Sep 05, 2011 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
I have power in the amp but its not powering my subs? they move when music is on but nothing as what they should?
need more input here.
what subs r u driving.
have you checked the input gain controls?
are you using low-voltage inputs or high?
what settings are set on the amp itself.
May 05, 2011 | Fusion EN-AM60010 600W Mono-Channel...
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
Hi, i have a 600w fusion amplifier in my house running on a transformer. when i turn it on the red light comes on but when it changes to green the transformer shorts out. its not the transformer thats...
How many watts is your power supply capable of supplying to a given load. There could be a problem with your amp. The quiescent current should be in the high mA to low A range which in no way would cause your supply to overload.
Dec 20, 2009 | Car Audio & Video
How do i wire a fusion 12'' active encloser up to my car?
OK. (1) The RCA's plug into your audio-In on your amp and the other end of your RCA's plugs into the back of your cd player's audio-out. (2) The small blue wire is the "Remote wire" the one end is wired together with a blue wire in back of cd player other end to amp..To attach wire "remove some of the rubber insulator on wire about a 1/2 inch then twist wires together and put electrical tape to cover or wire nut if you have one." (3) "Ground wire" this is the black wire one side to "amp - neg" and the other end to frame of vehicle. " find a bolt in trunk and put the end of the wire around that and tighten bolt" but before putting bolt on take sand paper to the metal frame where the bolt hole is and sand all the paint off! (4) Last Power wire the "red wire". Cut about 12 inches off power wire plug one end to "amp + pos" the other end to the fuse...Now with the rest of the Power wire plug the one end to the otherside of fuse and run that threw car either driverside door or underneath the dash to the "+ pos red" side of battery.
Then your done! Good luck! and wire in that order and you want blow anything! Give me a thumbs up if you like!
Sep 24, 2009 | Car Audio & Video
Locking the jar on the base Oster Fusion 600W Blender
Here is the user manual for the Oster Fusion:
http://www.osterfusion.com/Manuals/MANUALS/BRLY07-Z00-000_43_29190737.PDF
It looks like you line up the threads, place the base on, and twist to tighten.
-Tha Mp3 Doctor
Mar 19, 2009 | Oster Blenders
I am trying to wire and bridge a sony marine 600w sony marine amp
as long as the speakers are wired in parallel it should be ok dont wire them in series as they will overload the amp it is designed to run at 4 ohms
Feb 13, 2009 | Sony XM-2150GSX Car Audio Amplifier
Fusion Digital designs PP-AM8004 Car Audio Amplifier Logo
146 people viewed this question
Top Fusion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
