see this causes and fix it. God bless you
User Control and Display Board
If the washer won't start, the user control
and display board may be defective. Check for power to the washer first.
Timer
If the washer won't start the timer might be
defective. This part is often misdiagnosed, check other components
before replacing this timer.
Line Fuse
If the washer won't start the line fuse might have blown.
Thermal Fuse
If the washer won't start the thermal fuse
may have blown. It can be tested for continuity. Watch our fuse testing
video for more information.
Line Fuse and Holder
have blown, or the line fuse holder might be damaged and need to be
replaced.
Main Control Board
If the washer won't start the main control
board might be defective. This is not common. Check other parts and
causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch
assembly might be defective. This is a very common problem. The lid
switch assembly can fail either mechanically or electrically. Test any
electrical switches with an Ohm meter for continuity. The switches
should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't start the door lock
assembly should be checked. The door lock can fail either mechanically
or electrically. Test any switches on the door lock with an Ohm meter.
The switches should have continuity according to their design.
Incoming Power Problem
If the washer won't start check to see if
there is power at the electrical outlet which the washer is plugged
into. Plug a lamp or radio into the outlet to check it. If the outlet is
dead, check the circuit breakers or fuses for the home.
Power Cord
If the washer won't start, check to be sure
there is power to the electrical outlet for the home. If that is OK, the
power cord itself might be defective. This is rare. You can check the
power cord with an Ohm meter for continuity.
My Toshiba TDP-S8 has the same problem, will not power up, but sometimes after it has been plugged in for an hour or so it will then start. The bulb at my last check was under 600 hours usage. one time i had to leave plugged in for over a day before it would go. Any thoughts?
Could it be something to do with the standby?
I have more or less the same problem. After switched off from the mains it takes 2 hours + before the standby light goes on and I am able to switch it on again. Also once in a blue moon it will start up with no image (only faint grey background) and won't switch off again - only solution is to unplug, let it cool, plug in but then the original problem keep you waiting for 2 hours before you can switch it on!
yes my unit will not turn own.. its like its in stanby mode,, i will plug it up and the stanby power light will just blink for a while,.. then it will stop... but when i up plug it and plug it up again, it will start blinking again....
what should i do...
I have the exact same problem. Once when it actually powered up I checked the blub life and it was only at 361 hours. I don't think its a bulb problem...
