Question about Amana ACF3355AS Gas Kitchen Range
Oven door won't close tight
Amana (model ACF3355AS) door won't close tight, light stays on
  • rjswart Feb 26, 2008
    thanks, I'll order the springs
    President:
  • Amana Master
  • 2,651 Answers
Order and replace door springs part # 32052801 youll need 2
Posted on Feb 26, 2008
Why will the door not lock and stay closed ?
Ithink the door clips spring is loose inside so openthedoor cover orjust move your door clips by hand it must not be too loose
Dec 08, 2014 | Amana Microwave Ovens
Amana Br22tw refridge door won't stay closed
Check all the screws for the hinge and be sure the door is lining up properly.
Oct 23, 2012 | Amana ABB1927DE Bottom Freezer...
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
My Amana gas range's oven door will not stay shut. It is not snug against the oven. Repair says I need new hinges. Are they easy to replace?
they're not too bad, you may need to take apart part of the door to remove the hinges, just remember where everything goes as you take it apart. bring the door to the first stop, then bring the hinge pin locks into place to secure the door hinge lock, then remove door, or just slide the door up. then replace the hinges as needed.
Jul 09, 2009 | Amana ACF3355AS Gas Kitchen Range
Oven door latch does not lock - I was told part no longer available
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
May 07, 2009 | Amana ACF3355AS Gas Kitchen Range
Temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
Oven door hinge replacement installation
kitchenaid superba oven door will not stay closed.
Oct 22, 2008 | Kitchen Ranges
Amana ACF3355AS Gas Kitchen Range Logo
1,139 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
