Pansat 2500a FTA receiver
I have Pansat 2500a fta receiver and bought the following cables:
1. Radio shack USB to 9 pin RS 232
2, RS 232 cable
I connected the RS 232 to the receiver and the other end to Radio Shack 9 pim and the other end USB to my computer. Radio shack software installed.
I used the blacklist updater loader and a file from FTA talk. Loader download percentages 0% but wont load to receiver.
Can sombody help me.
  • 2 more comments
  • jomantec Feb 22, 2008
    The RS-232 cable hasa straight thru wiring configuration. Someone gave it to me recently and I dont know if he loaded any program and theres no way I can find out. I appreciate your response.
  • jomantec Feb 23, 2008
    Now I know why, the guy who sent me that RS 232 cable sent me the wrong one. He sent me a SQUARE edge cable connectors. A friend of mine showed me his original cable, the edges are rounded. Hopr if i GET MY NEW ONE IT WILL WORK. Pansat 2500 cables are pain in the neck.
    Thanks you all guys for the help
    Thanks so much JAIME867, you are a good samaritan. Good job
  • Jaime Hernandez May 11, 2010
    Is the RS 232 a serial cable and not NULL?
    Have you loaded any program on this receiver before?
  • 2,326 Answers
I would suggest to go here to get a lot more info on how to program this receiver.
Posted on Feb 22, 2008
  • Jaime Hernandez Feb 23, 2008
    Once you have the correct cable, you will be able to load the programs in your Pansat. I would suggest to visit the site i gave the link and register, you will find all the help you need to get your receiver working.
    Good Luck.
Dual control noted on Dish tv screen but cannot change stations separately on both tvs
Each TV receiver has to be fed with a separate cable from the lnb. They can not be bridges or split.
Mar 09, 2015 | Dish Network/Pansat Dish Network Dish 500...
Activation of keys on an FTAS receivers
Your query > "Instructions on how to install new keys and activate an FTA receiver using a 2GB Cruzer Micro Flash Drive with 3 smarth technology"
Generic responses:
1. depending on your FTA receiver (brand/model/version) (BlackBird, MultiStar, UltraStar, Pansat, Digiwave, Viewsat, Coolsat, Fortec, Ariza, Twinhan... or even clones) you would need to download the appropriate firmware/satellite keys using your PC & Internet connection;
2. links to firmware/satellite keys maybe available from your FTA receiver manufacturer's website or forums such as HashHU FTA
3. in your PC, unzip the downloaded firmware/satellite keys to a temporary folder;
If you are using a stand-alone hardware FTA box:
a. plug in your 2GB Cruzer Micro Flash Drive to one of your PC's USB port;
b. copy/paste the unzipped files in the root directory of the Flash Drive. Verify that you have the .bin or .pmg of whatever your FTA box is using;
c. remove flash drive from PC's USB port and insert into the USB port of the FTA receiver;
d. on the FTA box, using your remote, go to Menu, Settings or Sytem Information, keys, firmware or receiver Upgrade, select USB, select Flash, Save, Activate or Upgrade;
e. wait until the FTA box has uploaded to itself the new firmware/satellite keys;
f. reboot (power on/off).
If you are using PC-based FTA satellite receiver:
i. run your FTA receiver program;
ii. select for Tools/Options/Upgrade or Update;
iii. browse/direct to search in your temporary folder where downloaded files were unzipped;
iv. once found, click OK/Update/Upgrade;
v. in some brand/model/version, there is an auto upgrade/update feature which will download appropriate firmware/satellite keys if you are online.
Hope that the this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 24, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Need to reset a pansat 3500sd
that sounds like a FTA unit? there are tons of free download bins for the factory reset of the fta reciver there are no longer easy bins to revive or to hack the unit to receive pay TV because they all have switched to what is called the N3 system and that has not been hacked yet but there are tons of pay sites online for thease bins BUT Not the N# BINS At least not yet that I am aware of!!!!??
Larry Dillon
Aug 26, 2009 | Televison & Video
I need sabrent usb to serial converter drivers.The disk I received with my parches does not load!?
Try searching the following page
Feb 20, 2009 | Sabrent USB to Serial (9-pin) DB-9 RS-232...
Programing a uniden BC246T
Not all programming software supports usb. Either find software that supports usb or you can buy add on cards to your pc that will give you a serial port. Hope this helps
Jan 26, 2009 | Uniden BC246T Handheld Scanner
Driver needed
I found my disc. Problem solved. Thanks for follow-up.
Jan 11, 2009 | Sabrent USB to Serial (9-pin) DB-9 RS-232...
Coolsat 6000 fta connection
if your hooking it up just to ur TV you would need The RCA Video Cable, Video- yellow, Red - right, white is left,Witch is printed on the back of the box, this would go into the output an go in to TV input
Hope it works
Oct 17, 2008 | Toshiba SD-H400
Normal RS -232 cable
5 4 3 2 1
9 8 7 6
1 - Not Used
2 - Transmit Data (TD)
3 - Receive Data (RD)
4 - Request to Send (RTS)
5 - Clear to Send (CTS)
6 - Grounded
7 - Signal Ground (Gnd)
8 - Data Carrier Detect (DCD)
9 - Data Terminal Ready (DTR)
Sep 30, 2008 | Computers & Internet
Televison & Video Logo
253 people viewed this question
Top Televison & Video Experts
