Question about Foxconn P4M9007MB-8RS2H Motherboard
Pin layout for the Front Audio Connector
I was wondering if anyone could point me to a web site or tell me via this site the pin layout for the Front Audio Connector.
    President:
  • 2,351 Answers
Hi HomeCPU, if you do not have a manual for the P4M9007MB-8RS2H motherboard than lick the link below & dowload it.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000243
Goto Pg.4- Front Audio Connector Board layout.
Than to Pg.13, Audio Connector: F_AUDIO detailed pic of pin loacations.
please vote...
Posted on Feb 22, 2008
Http://www.woodscomputers.com.au/Foxconnaudio.php
Posted on Apr 08, 2008
Manual needed
Paul,
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/
Download> Select OS (I just clicked on WinXP) > Click on the + sign next to Manual (5)
Version 1877
P4VP-MX user's manual English version E1877
2.5 MBytes
Click on the blue -> Global
Or copy this,
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4vp-mx/e1877_p4vp-mx.pdf
Paste it in your address bar, and press the Enter key.
(May take up to 30 seconds before the first page comes up)
Page 17 - Motherboard Layout
(PDF file page. 1-7 for the actual manual page)
Page 28 - Front Panel Audio Connector (1-18)
Page 30 - USB Header (10-1 pin USB56) (1-20)
Page 32 - System panel connector (10-1 pin PANEL1) (1-22)
The front of your computer is the Front Panel.
The area of pins on the motherboard, that the main cables, (Wires), go to, is the Front Panel header.
Motherboard as installed in computer case;
Processor to the top, Ram Memory slots to the right, white PCI slots to the bottom;
The Front Panel header is located at the Bottom/Right corner.
PANEL1.
Two rows of pins.
(To the left of it is the front panel USB header. USB56. Looks very similar)
Doesn't show numbering for the pins. (Contact pins)
I'm going to number them for easier orientation
The pins across the TOP are numbered ODD.
Starting on the LEFT side going towards the Right;
Pins 1, 3, 5, and 7. There is NO Pin 9.
The pins across the BOTTOM are numbered EVEN.
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the Power On LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the LED is dim when the computer is on, switch the wires around.
B) Pins 5 and 7 are for the Power On switch.
C) Pins 2 and 4 are for the HarDDrive activity LED (Light)
May be marked on the wires as HDD, or IDE.
Pin 2 is for the Positive ( + ) wire.
If the harddrive activity LED is dim when the harddrive is active, switch the wires around.
D) Pins 6 and 8 are for a Reset switch, IF a Reset switch is used.
E) Pin 10 is N/C
Not Connected. (Probably a +5 Volt point for the factory to use)
Have problems downloading, or saving the PDF manual, post back in a Comment.
For additional questions post back in a Comment.
Regards,
joecoolvette
[Motherboard chipset;
Northbridge -> VIA VT8751A (Also known as VIA P4M266A)
Southbridge -> VIA VT8235
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Socket_478
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[CPU = Central Processing Unit. Another term used is Microprocessor, or simply -> Processor, for short ]
Jul 09, 2012 | ASUS Computers & Internet
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
Dell GX270 SATA front panel 34 pin layout
if you are talking about connecting the front chassis connectors to your motherboard then you need to find out the exact model of the MB... im assuming its Intel since its a Dell.
the link below should get you started
http://www.intel.com/support/product.htm
Jun 01, 2009 | Dell OptiPlex GX270 PC Desktop
Lenovo J115 with new Gigabye motherboard - case fan set up
Lenovo's web-site: http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do
should have the information.
What connectors are leading from the front-panel?
One "clump" of wires and one connector, or several separate connectors?
May 27, 2009 | Lenovo 3000 J115 (7387-A11) Desktop...
Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
Pin settings for Acer Veriton 5600g motherboard
go to this site download vt5600.pdf file when downloaded sellect point 4 upgrading you computer,\system boards\mainboard layout\veriton 5600g mainboard layout.
http://www.acerpanam.com/synapse/data/7117/documents/vt5600.pdf
good luck
terry
Feb 20, 2008 | Acer Veriton 5600G PC Desktop
Foxconn P4M9007MB-8RS2H Motherboard Logo
1,251 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
