Question about Canon EOS 20Da Digital Camera
Error report 99 on my Canon 20D
Getting a error report on my Canon 20D and it will not reset after I remove my battery.
    President:
  • 4,402 Answers
Take out battery for a few mins and that resets the error, well it worked. or Before I reset it, take off the lens and put it back on.
i heard that some have problems with the lexar cards.
http://www.lexar.com/support/cust_advisory.html
in short, format the card every so offten in the camera and see if that fixes it.
also
try a firmware upgrade if your 20D has highest version get this at canon website
Posted on Feb 22, 2008
Error 99 when using Quantum Transceiver
Error code 99 is a non specific error code a sort of catch all. Remove the lens and clean the contacts (lens and camera), remove the battery and the memory card. Leave the camera in this state for about 10 mins, enough time to discharge any build up of charge or static. Reinsert the battery and the memory card and reattach the (cleaned) lens switch on leave for 5 seconds and press the shutter button to see if this has cleared to problem.
Jul 09, 2014 | Canon EOS-20D Digital Camera
What is error 99 in canon eos 20d
It's a frustrating catch all error and needs service.The camera may have any one of numerous issues or lens issues. If you have more than one lens, see if the error occurs with both lenses on. If not then it's a lens error. A camera repair facility can plug unit the camera and download a more accurate troubleshooting code. Royal Camera Service in Hanover Park, IL is good source for this problem. The replaced the shutter on my 20D when I got the error 99 code.
Feb 06, 2013 | Canon EOS-20D Digital Camera
Canon eos 20d error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 20d service manual link:
http://goo.gl/YtVLQR
it will help you to save a lot of money
Hope it helps, Thanks
Aug 07, 2011 | Canon EOS-20D Digital Camera
I got error 099, before I was getting error 05. and the flash dos not open canon EOS 20D
I also get the error 99 message and cannot take any photos... I have been able to solve this problem by taking out the batterys and wiping down the connectors on both the batterys and the connecters in the motordrive with a lens cloth. keep the lens cloth on hand when shooting. It may be that either oils, or dirt has gotten onto the connectors. I hope this helps.
Mar 23, 2010 | Canon EOS-20D Body only Digital Camera
Sigma 70-300 error 99 on canon 20d &10d
If the macro switch is held on the lens by 2 screws it is to old and will on work on your camera but if yous is a super type it may need a rechip
Nov 13, 2009 | Sigma Zoom Telephoto 70-300mm f/4-5.6 DL...
Cannon Eos 400D Err 99?
Error 99 is a NONSPECIFIC error message. It is almost always associated with the LENS. I first got this error on my EOS 20D whei I tried to use an older Sigma zoom lens (7 years older than the camera). I don't use off-brand lenses with my Canons. Try removing the main battery first followed by the time & date battery which is hidden in the battery compartment beside the main battery. This will reset your camera. Good Luck!
Nov 30, 2008 | Cameras
Err 99
this is what the canon people say to do for error 99
Read this!!!
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked eaaa19b.jpgb9433a1.jpggood luck!! have a nice day :) :) :)
Aug 07, 2008 | Canon EOS-20D Body only Digital Camera
Error in body
Remove lens, CF card, and battery. Leave in a dry and slightly warm place for 24 hours. Clean lens contacts with a cloth or cue tip and eclipse/alcohol.
If the camera doesn't turn on after this, even without CF card and lens attached, then it needs to go to a Canon service centre. Don't tell them you got it wet, and maybe it will get repaired FOC.
Jul 07, 2008 | Canon EOS-20D Body only Digital Camera
Error 99 in body
Jul 07, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Error 99
I get error 99 sometimes on my 20 D but it?s usually to do with a lens that is attached. Sigma lens have been known to cause error's. If it's not that or dirty contact on the lens then it could be a more serious problem. I would at least check it out with a canon dealer/repair centre.
Sep 14, 2005 | Canon EOS-10D Digital Camera
Canon EOS 20Da Digital Camera Logo
157 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
