Question about SanDisk Sansa e200 MP3 Player
Frozen sansa everytime i try to add more songs into my sansa, it works but when i disconnect it freezes, so i restart it but then the songs aren't added. help!!!!!!!!!!!!!
    Novelist:
  • 141 Answers
1-866-726-3475 Sandisk Customer Support
www.sandisk.com
click on support at the top; click on MP3 players,
find your Sansa and click on it there’s a lot of info
You might want to restore to factory settings. Only problem, you will loose all the music etc in your Sansa, but it should work. First back up the media on your Sansa to your hard drive, flash drive or SD card so you can reload it more easily.
Posted on Mar 27, 2008
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
SanDisk freezes when trying to play a song, then it restarts itself.
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works.........Try and drag and drop from your music folder to the media folder on the player make sure usb mode is mtp this will show you all the folders Use your windows explorer for the transfer... much easier.....
Then disconnect from your computer and see if it worked
Hope it does..........Please rate
May 17, 2009 | SanDisk Sansa e260 MP3 Player
Freezing
Use Windows Media Player to delete unwanted songs.
Several of the methods I have listed bwlow will erase everything off your player as a side effect:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 15, 2009 | SanDisk Sansa e250 MP3 Player
Songs Freeze up
go to my computer> properties>hardware > device manager >universal bus driver>right click on it> update driver>
then1
1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer
Then try to format your drvice sir
your problem will now soved
Feb 05, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa e250r works but will not format
The issue you have described with your portable device in most cases can be resolved by formatting your device. Please follow these steps even if you have already attempted them once before.
Please note that this will remove all music from your device.
Formatting the device in Windows Media Player
1. Open Windows Media Player with your MP3 player connected to the computer
2. At the top of windows Media Player select the Sync tab at the top
3. The MP3 player should be recognized on the right hand side and say "Your Player Name"
4. Above the player name is a button that says "Format Storage Media" click this button to erase all the data from the player
Nov 02, 2008 | SanDisk Sansa e250 MP3 Player
Sansa 2gb mp3 player
-Tha Mp3 Doctor
Jul 21, 2008 | SanDisk Sansa e250 MP3 Player
Sansa clip freezing on refreshing data!
An easy solution is just let it sit over night and it should go back to normal, but you may need to charge it though.
Jul 15, 2008 | SanDisk Sansa Clip MP3 Player
Worked only once
You probably synced songs that were in the wrong format - see my 2-part article under my profile on song formats for a more details explanation. Short answer: convert all osngs to mp3 format
-Tha Mp3 Doctor
Jun 30, 2008 | SanDisk Sansa e250 MP3 Player
My mp3 player
ok here is the thing mp3 players work on bit rates ,
meaning if your bit rate is over 128 bits
unit will act weird
so what i suggest is you erase and reformat and only install songswith bitrate of 128
here is a link for ree songs dont sign up to b a member just use tral version and you can also get videos
www.limewire.com
rembe only 128 bits and you wll be able to get more on your unit
hope this help
richard from chicago
Feb 22, 2008 | SanDisk Sansa e200 MP3 Player
New song
make sure the cords r plugged in properly. Then you can try to unscrew the 4 screws in the back and pop out the battery. make sure you put the battery in right and if that doesn't work download your songs from a different place.
Feb 22, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
55 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
