Question about Siemens SpeedStream Modem (4100) (SS4100)
Tring to find out how to hook up a dsl modem
I want to be able to surf the web any time but still recieve al my calls to.
    Genius:
  • 3,587 Answers
Hmmm..not usual for modems to work that way..ever considered a skype computer phone line?
check your warranty for FREE here
Posted on Feb 22, 2008
My dsl light will flash red when im surfing in the web and then it will restart normal for about an hour then the same thing will happen so what should i do ive reboted the system and power cycle it and...
Good day. For your problem as suggest for you to contact at&t and ask for a modem replacement. It should not take an hour for your dsl light to turn solid green. A red light also indicates a problem on the modem itself. Better to get it now than to lose your connection permanently in the future. Hope this information help you a lot. Have a great day to you.
Jun 12, 2011 | AT&T High Speed DSL Modem
Can you hook up dial-up to a dsl modem
Can you hook up a dial up what to a dsl? A modem? No, you need a dsl modem for a dsl line. Typically, a dial up is POTS (Plain Old Telephone Service) and connects to a POTS 56,000 K modem. DSL will run much faster but not as fast as cable.
Jun 05, 2011 | Computers & Internet
How to set up wbr-3406 tx router with dsl modem
Take an Ethernet cable, and connect the Ethernet port on the DSL modem to the WAN port on the router.
Take another Ethernet cable, and connect one of the LAN ports on the router to the network-port on your computer.
Now, you should be able to web-surf.
Access the web-server inside the router, and run the "Wireless Network Setup Wizard", to configure your wireless networking.
Jun 24, 2010 | CP International WBR-3406TX Wireless...
When my phone rings the kids get booted off xbox live and i have wireless internet and wireless adapter for xbox360
Hi Jeannie,
Based on your problem I assume that you have DSL. When you get hooked up for DSL they send filters that you are supposed to put between EVERY phone and the jack. (Don't forget phone lines for satellite and alarm systems).
If your dsl drops every time the phone rings, there are usually 2 things that cause this.
1) A bad filter in your house. If a filter is bad or missing it can cause the dsl to drop either when the phone rings or if someone picks up the phone with the bad filter.
2) The other reason could be on your ISP's side. It's called a POTS splitter. You have one of these if you have BOTH phone and DSL. It's what sort of combines the 2 together. There are a number of problems that can occur with a bad pots splitter. i.e. DSL works - phone totally dead, Phone works-dsl - totally dead, disconnects, etc...
I suggest that you hook up the dsl modem by itself. DISCONNECT ALL PHONES IN THE HOUSE. Do NOT have anything connected at all except the dsl modem. No filters, phones, directv, digital cable, or anything else in a phone jack. Then when you are up and surfing, take your cell phone and call your house. Technically it should just ring and ring. Unless you have voice mail in which case it will go to voice mail after so many rings. Anyway, see if when the line is ringing in your cell phone if it is dropping you off. If it DOESN'T, then it's probably one of the filters, jacks, or wiring. If it still disconnects, it's probably the POTS splitter with your ISP.
Good luck and if this helped please help me out and leave feedback!
Thanks!
Feb 08, 2010 | Computers & Internet
Just connected router to clear network modem and VoIP (wireless phone service), now when the phone ring, it disconnects me from the internet and the connection is lost until the phone call is complete.
Is your modem a DSL or cable modem?
If it is a DSL modem do you have a DSL filter on each phone line to the phones in your house?
The DSL modem does not need a DSL filter on the phone line.
Nov 09, 2009 | NetGear WGR614 Wireless Router
I can't get on the internet
>> do i have to call my internet service provider to activate my modem?
Yes.
Each modem has a unique "address", and your I.S.P. uses that address to authorize each DSL-modem that tries to connect to their network.
Or, if the two of you live in the same house/apartment, you should just buy a "router". Then, both computers can connect to the router, and the router connects to the DSL modem, and both of you can "share" the monthly fee for the _one_ Internet connection.
May 27, 2009 | AT&T High Speed DSL Modem
"no answer" on receive
If you are recieving faxes normal and you get this message once in a while its more likely someone is tring to call you via the phone or if you press the HOOK button and you press the GREEN start key the machine will go into recive and time out if it doesn't hear a fax tone within 30secs it will time out and give ypu this message.
Mar 09, 2009 | Canon LaserClass 7000 Plain Paper Fax
I m using broad band. i want to answer the landline calls through my dsl modem. how can i do that?
Well,
with any broadbank connection, you can surf and talk at the same time... all you have to do is to make sure that the filter is installed on the phone line and that the splitter/2way pin is installed on the telephone wall jack... dsl cable should not be filtered.
run speed test @ http://primustel.blogspot.com
Dec 05, 2008 | Westell Wirespeed LiteLine 6100...
2.4 gigahertz phone
if ur dsl is hooked to ur phone that means every time u reciev a call that means ur broadband link is disconnected for awhile.
Sep 27, 2008 | 2wire (1000-400108-001) Router
Cant connect thru DSL(LAN)
hey there i am having a problem with my Vista home premium. = false
I cant connect or get my broadband connected to DSL. = true
but everytime i use my fone as a modem i can surf the net. = true
how come i cant do this with the DSL Line?
1. Your DSL line requires a special kind of modem a DSL modem not a phone modem.
Thank you for choosing FixYa!
Az. Wizard Division.
Sep 23, 2008 | Microsoft Windows Vista Home Premium with...
Siemens SpeedStream Modem (4100) (SS4100) Logo
290 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
