I have a samsung 46" dlp TV. Everything on it was fine until last week. I turned on videogame (Nintendo Wii) and there are 4 vertical bands and green lines. I thought it was the videogame but then when I tried to play a DVD the same thing happened. The TV is working fine through the cable box (HDTV is working fine too). I changed the connectors from AV1 to AV2 and AV3 and same thing happens. The TV was bought in 2005 and has very little hours on it.
  • 4 more comments
  • kadry Feb 22, 2008
    No....not at all....the image in the you tube video was very clear and it seemed like the lamp was pulsing. On mine, the image is almost a ghost image that can hardly be seen in back of scraggly, alternating black and green lines.
  • kadry Feb 25, 2008
    Model # is: HL-R4667W
    Astrobyte....yes it seems to be the same tho I don't have any pink lines. Just out of curiousity...I suspect a power surge may be involved. The other day I found the circuit breaker tripped and had to reset it. All my equipment is plugged into a power surge protector except the Wii videogame console. Could a surge possibly burn out all video inputs even if the Wii was only connected to AV3?
  • kadry Feb 26, 2008
    Would you believe it....my Wii came back from Nintendo yesterday; they said the board had been replaced. I plugged it in and this time I hooked it to the power surge protector and AV3...everything worked fine. The DVD player is also now working fine. No one can explain this sequence of events!
  • kadry Feb 27, 2008
    Talk about a downer. I turn on the system today and its doing the same thing again. AV3, S-Video DVD and Cable 10 have five greenish vertical bands and screen is green and black. The TV works fine off the cable box. And I canceled the repair order!
    The picture looks like this on AV3 (nintendo) and s-video inputs. TV picture from cable box on component input is fine.
    Scholar:
  • 110 Answers
Hiya Kadry! Does the problem look like this at all?
Video
If it does, or if you have similar lines and banding I'd suspect the problem is with the color wheel that is part of the DLP mechanism. If that's the case, you will need to have the TV serviced.
Posted on Feb 22, 2008
  • 2 more comments
  • Robert Swanson
    Robert Swanson Feb 25, 2008
    Is this similar to your issue?
    Click here
  • Robert Swanson
    Yes, unfortunately, it is possible. It's even possible through it's own surge protector if it is underrated for whatever jolt came through.
    Sorry that it has to be all bad news, especially since it's probably just out of it's warranty period. I'd still recommend having a service estimate performed.
  • Robert Swanson
    Robert Swanson Feb 27, 2008
    Sorry to hear the turn of events you had. It does strengthen the suspicion that a board is bad, but it could just be a loose fitting or solder connection that came back and went out again from movement when hooking stuff up.
  • Robert Swanson
    If it were me, I would definitely reinstate the repair order.
    President:
  • 4,402 Answers
Samsung HLN5065W - Vertical lines on Screen
the screen flickered and about 10 sets of 1/8" vertical black lines, in groups of 8, appeared across the screen. They flickered on and off,
you have a bad dmd module and it cost around $750-$800
Happend, because a bad soldering connections in that module. Lines will come on and off. Probably 1 day will stay on. For last 2-3 years it seen that only on hlm and hln series. Probably
happens on other models. but, i never seen that.
Is not that hard to replace that module. You have to remove 2 screws from left side and 1 screw from bottom right side of module and 4 of them
from around dlp unit unplug all cables ( i think
3 cables ) that it. Same way install new one in.
but you will need to adjust a module position to get
picture to fill whole screen.
Samsung > HLN467W
vertical lines
Light engine
  • Cary Farah
    Cary Farah Feb 25, 2008
    do you have model number?
    President:
  • 1,944 Answers
Did you check to see if the cables are fine? Try another set if possible.
  • Damen Wong
    Damen Wong Feb 27, 2008
    Interesting...nevertheless, I am glad it worked out for you in the end.
Wii Freezing (Band Hero)
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aaa1
Jan 12, 2010 | Nintendo Wii Console
Small white dots are emerging all over my Samsung DLP TV - 46`
Bad Light Engine,Call UED for price of rebuilt one!
1-800-648-6657 TIP if you have never replaced color wheel,they 9/10 go bad also!
Sep 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Dlp vertical lines
the person you talked to at samsung is more than likely a customer support rep that does know anything but what his computer tells him. i have seen this symptom several times in many makes and models. if you can give me your full model number i will give you a part number to fix this issue.
Oct 24, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Televison & Video Logo
184 people viewed this question
Top Televison & Video Experts
