Question about LG DLE5977 Electric Dryer
Dryer overheat and stoppping too soon
I was told that usung dryer sheets in these types of dryers causes a film on the dampness sensors and causes eratic operation (i.e. shortened drying cycles, etc
    New Friend:
  • 60 Answers
Yes, dryer sheets can cause a build up on the sensors and the lint filter. Clean the metal contact strips off (just inside the door) with alcohol or windex and use a toothbrush and a little soap to scrub the lint filter. With the build up you don't get proper airflow and it won't dry right. Also, stop using dryer sheets or be sure and clean the cotacts and filter about once a month.
Posted on Feb 26, 2008
How do you adjust the moisture sensor?
The moisture bars are not adjustable in dryers, it is required they be cleaned with rubbing alcohol followed with a rubber eraser, mainly if dryer sheets are used regularly. Loads that are too small for the capacity of the dryer will also cause the dryer to shut off too soon leaving the load still damp, in cases of that, a "more dry" setting should be used. Pleazer Appliance...
May 02, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
Westinghouse dryer ld505e on/off button wont stay on when l push it
If it has dampness sensor strips inside the machine they may be coated with dryer sheet wax or some other mess. Clean them with windex and retry. As the clothes rub against these sensors the dampness causes the dryness board to keep the machine a going. if no dampness is detected the dryer shuts down. Supposely to save power.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 18, 2012 | Westinghouse Dryers
Duet gas dryer only drys on timed
One thing you can do is clean the sensor strips located inside the dryer. Get some windex and clean the coating off them. Dryer sheets rub against the strips and form a barrier. The machine THINKS the clothes must be dry because it ain't SENSING dampness from wet cloths rubbing against them sensors.
Oct 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The sensor on my dryer is not moving off the sensing over to wet, damp, dry or done. the dryer is heating but the sensor display does not seem to be moving. Model # wed6200sw1
In some cases this can happen, I have found by cleaning the sensor located inside the drum area with a rag and water or rubbing alcohol this will remove the residue from dryer sheet and should detect your clothes better. Over time the residue can build a barrier can cause this to happen. Normally this is a simple and quick fix.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 15, 2011 | Dryers
Heat inside dryer---clothes not drying, vent damp
If your dryer is STILL heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some items to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. Please include your MODEL NUMBER, so I can determine how your dryer is configured. I hope you find this information is helpful.
NOTE: Dampness inside the dryer ventilation ducting is a sign of a clog, excessive duct length and/or a kinked hose.
Jan 21, 2010 | Dryers
After the dryer shuts off (automatic cycle) clothes are still somewhat damp. wondering if there is a monitor or dampness gauge that is dirty?
There may be.Look inside the drum. The dampness sensor looks like two metal strips a few inches long. Try to clean them with a cloth soaked in rubbing alcohol. Dryer sheets can leave a residue on them that causes them to read wrong. Good luck.
Jan 03, 2010 | Dryers
My simpson 1200s heavy duty clothes dryer is just not drying the clothes. It isn't heating up much and the clothes are still damp. Can you advise please
check venting fo cloggs or kinks make sure you can see through the filter dryer sheets put a film on them and need to be washed once in a while
Jun 28, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Wirlpool dryer heating eliment keeps braking
Sounds like you use dryer sheets. If you do, try cleaning your lint screen with vinegar. Dryer sheets leave a film on the screen that the dryer eventually can't breathe through, the dryer overheats and burns up the elements.
May 26, 2009 | Whirlpool LER5636P Electric Dryer
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
LG DLG2532 Gas Dryer will only dry on manual setting
If you use dryer sheets, LG recommends no.  Dryer sheets cause a film that will not allow the sensors to feel the clothes moisture during the drying process thereby causing the computer to countdown the timer quickly.  To clean out the sensors, use a green pad and scrub the sensor bars inside the dryer drum.  That should remove the film left by the dryer sheets.
Mar 12, 2008 | LG DLG2532 Gas Dryer
LG DLE5977 Electric Dryer Logo
134 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
