Question about Bosch WFMC 3200 Front Load Washer
Bosch front load needs new gasket
Hi, I hope someone can help. I have a Bosch front load washer and the rubber gasket around the drum has ripped. It is causing the washer to leak. where, how, how much can I get the gasket ? I know it can replaced because I saw a release place. Thank you for your help!
  • 1 more comment
  • Anonymous Mar 09, 2008
    my washer is a little over a year old and it needs a new gasket plus it stopped spinning out the watrer
    i paid over 1100 for it because it was supposed to be such a good brand
    i would ***** get another one
  • Cherylnsal Apr 28, 2008
    BOSCH WFMC3200UC washing Machine
    Rubber gasket ripped! Need to order one and put it in! Washer leaks on bottom!
  • Anonymous Mar 16, 2014
    bosch washer replacing boot gasket
  • Bosch Master
  • 744 Answers
Bosch WFMC 3200 Front Load Washer needs to replace
door gasket.
This video will show you how to change a door seal or gasket on this Bosch front loader washing machine and also where to buy parts!
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 05, 2013
Yaaaa.. Well next time after we paid fixit 100.00 and a few gashes in our hands.... and 5-6 hours later! I will throw the washer OUT!
Thanks 4 nothing,,,,,
Do NOT BELIEVE THIS IS EASY! ITS NOT.....
Posted on Jun 01, 2008
Next to nothing? easy to replace hmmm.
Posted on May 31, 2008
  • 10 Answers
I think you mean the (door seal), and yes they can be replaced and at little cost and little effort, with out knowing what model your machine is i cant give you an accurate price quote but should be able to pick one up for for next to nothing if you look around. happy to give instructions on how to replace the old one if needed.
Posted on Feb 22, 2008
Water leaking from Bosch washer
Hi check the grey rubber seal around the door to the washer if there's a rip or tear if there is that would be the problem if not check pipes going to pump also water feed etc make sure all on and tight
Dec 23, 2013 | Bosch Axxis WAS24460UC 3.4 Cu. Ft. Front...
Wide gray rubber gasket between door and drum is ripped
the rubber will need to be replaced the cost is around $ 150 you can find washer repair service techs under washer repairs in your local phone book
best of luck
Jan 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My grey rubber gasket around the tub has a 1" rip in it. This is located where you open the front load door and on the grey rubber gasket just inside. Is there a patch kit? Or do I have to replace...
I search on google and no such patch kit. I tried a bike inner tube repair kit and it seems to work, but my holes are less than 1". Check out my post. I have a gasket on the way just in case.
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Drum came out of rubber skirt around door
Check that it is not ripped
Take the power off
Take the top off
Refit the gasket witha new clip
Dec 06, 2009 | GE WSXH208A Front Load Washer
I have a hole in the grey rubber seal that connects between the drum and the front. water leaks through and down the inside front panel of the machine. Can i buy a replacement part? How hard is it to...
You can buy a new door seal.
It is a fairly tricky job to do it your self.
To get some one to fit it, I would expect you tp be paying around £70.00 to £90.00 depending on who you get, so get some quotes.
Hope this helps.
Dec 02, 2009 | Bosch Axxis WFL 2060 Front Load Washer
GE frontloader door gasket ripped
We had the same problem, I printed off the solution posted by john_in_erie. His repair directions were VERY acurate, however we find a few helpful additions to the repairs - 1st in step #6, the spring loaded wire, is in the front of the gasket under seal (we were looking on top of machine). Also in step #8, you need a short phillips screwdriver or a 7 mm socket with a 1/4" ratchet because of the position of the screw to get around the edge of the tub.
Thank you so much John, we could have not done it without your very accurate installation instructions.
Lori & Mitch Headen
Dec 30, 2008 | GE WSXH208A Front Load Washer
BOSCH WASHER REPLACEMENT PART
I have the same problem. Bosch no longer stocks the replacement for my particular washer which has the same model no but could be a different fd #. I now have the wrong part as directed by bosch which doesnt have the hose connection. I am not sure what to do with the hose leading to nowhere. Bosch is living off of an undeserved good reputation.
In the present, the reputation is not deserved. Bosch products should only be recommended to enemies. The company and the especially the customer service is beyond deplorable. I hate these appliances. I feel ripped off! The part by the way, which is wrong, is 100.00 with tax.
Apr 28, 2008 | Bosch WFMC 3200 Front Load Washer
BOSCH WFMC3200UC WASHER
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Problem with front load washer
Are stains a brown rusty color? If so, this may be an indication that the rear drum bearing is going bad. The bearing itself cannot be replaced. You will need to replace the entire back shell of the wash tub. Hope you have a warranty. This can be an expensive repair. Let me know if this is the case.
Jul 08, 2007 | Frigidaire GLTF2940ES Front Load Washer
GE top load Washer ripping clothes
Solution!
GE has replaced the "boot" (the large rubber gasket at the opening of the washer) on my washer. This has fixed the problem!
Although the majority of people I spoke with at GE did not know about this, eventually I got a repair technician out here who spoke with one of the engineers. The engineer said that there was a problem with the boot causing clothing to rip. The new boot we have on our washer covers a ring of plastic just on the outside of the metal drum (the plastic rim remains stationary while the metal drum spins - this is the cause of the ripped clothing) - the old boot left this plastic ring exposed. Our washer was only 8 months old - so even if your washer is new, if your clothing is being ripped, insist that the boot be replaced for an updated version.
May 03, 2007 | GE Energy Star WCVH6260F Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
396 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
