Question about Pioneer AVIC-N2 Car DVD Player
Flipping out the unit will not come out or do anything when i press a button. i press the open button and it just makes the sound and when i press and others it does nothing.
  • 43 Answers
Thomas,
Unfortunately it sounds like the unit has sustained mechanical damage to the screen's drive mechanism - I would recommend removing it and sending it for service.
If that's not an option - you could probably try to manually pull it out and place it in the operating position and it might work. However that might also damage it further.
Posted on Feb 23, 2008
Need to reset as it is stuck on ready in 1 hour which we did not press. Tried letting it run but still stuck and no washing.
Hello. I really need the model number and make of the unit to help you most accurately. From what you describe, it sounds like the control panel might be defective. Also, the main board could also be corrupted. Have you had a power outage recently--about 3-4 weeks ago or sooner? Outages are NOTORIOUS damaging digital boards in appliances. The fact that you didn't press anything might mean that a button on the panel is shorted. However, to try to reset the board, try removing power from the unit by flipping the associated breaker in your power panel to off for about 2 minutes. Turn it back on afterwards and see if the unit will start. Let me know if you need further assistance. Thanks!
Nov 29, 2015 | Dishwashers
Trouble shoot moter on dryer
It may be the drive belt from the motor to the drum. If the dryer top flips up, you can see if the belt is intact, or is there a bottom panel that is removable? In any case the belt needs to be inspected. With that said, the 'strange odor' may very well be the motor. The motor / belt needs to be visually inspected. If anything is opened for inspection, be mindful of live wires and contacts.
Mar 25, 2014 | Kenmore Dryers
When I press the power button on my ultra hd 2nd generation camcorder, the screen lights up with the flip logo and verbage that says hold the record button for setup. It also makes the correct sound for...
Will the camcorder let you go ahead and complete "SETUP"?? if so, go ahead and redo the setup maybe some glich and maybe doing setup again may get the camera going again? hope so!! I have one also and knock on wood, no problems so far. it may be worth a try:
when camcorder turns on: when Flip Video Logo comes up press and hold RECORD button, to enter setup mode use the + and - to adjust current setting and the left and right arrows to select other settings
good luck!
Apr 25, 2011 | Pure Digital Flip Video Ultra Camcorder
I own LG VX8360 and can't figure out hoe to turn ringer on. Can you help me?
To restore the ringer it will depend on what mode your phone is in:
Vibrate Mode:
Sets the phone to vibrate instead of ring.
To set Vibrate Mode, with the flip open, press and hold the # key .
To return to Normal Mode, press and hold the # key again.
Sounds Off Mode:
Quickly deactivate your phone's sounds when you're in a place where phone sounds would be disruptive.
From standby mode with the flip open, press and hold the lower side volume key for 3 seconds. To return
to normal sounds mode, press and hold the upper side key.
Airplane Mode:
Turning on Airplane Mode will disable all wireless communications.
1) With the flip open, press the Menu key.
2) Use the Directional Key (top center of phone) to scroll to 'Settings and Tools'.
3) Press the 6 key for Phone Settings.
4) Press the 1 key for Airplane Mode.
5) Use the Directional Key to highlight a setting, then press OK.
On/Off
Mar 30, 2010 | LG VX8360 Cell Phone
I have a Moterolla V3,my LCD screen is not displaying correctly, I see white and red, but I can't make out anything else. When the phone initially turns on the screen displays the Verizon perfect...then it...
The flex that connects your screen to the phone board is bad and has worn out. It is commom with flip phones. All you need do is to replace the flex and be very mindful of how you close the flip phone.
Take care.
Nov 16, 2009 | Motorola Mobility RAZR V3
My GE Profile model WPRB8050D0WW won't start!
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 18, 2009 | GE Washing Machines
Chamberlain 1/2hp Operator won't work after electrical storm
Sounds like the circuit board got zapped. You could price a new board or take it apart and check the components if you know how, but normal mortals would just buy a new unit.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sanyo Xacti HD2 Flip Flash Not flashing
Hmm...I can't find a software control either. When the flash is down there is a cross through the lightening mark in the upper left portion of the screen, and when I press the flash button and raise the flash the same lightening mark in the upper left has no cross through it. Do you have the same mark? Does the flash button have no effect upon the mark?
Dec 18, 2008 | Sanyo Xacti VCP-HD2 Camcorder
My head unit is awkward.
Check the wire braid going out to the faceplate. Although this is a fancy feature. it is very problematic. But usually it looks like a flat plastic strip with brown stipes on it. Sony calls it a flexible circuit board. after so many flips wires break the buttons stop working and when the face gets just is the right place it stops turning. but is repairable if you can order the braid from Kenwood about a skill level five to put in.
Sep 07, 2006 | Kenwood KDC-519 CD Player
Pioneer AVIC-N2 Car DVD Player Logo
88 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
