Question about Mintek DTV-263 26 in. LCD Television
DVD stuck in player
I have a Mintek HDTV with builtin DVD player. There's a disk stuck in the drive. Help!
  • minniesmom Mar 04, 2008
    I have the exact same problem. Only thing that works is on/off button. All other options no not respond. DVD stuck in disk drive. Mintek seems to be out of business. I called the support site and they wanted $129.00 just to look at it and then charges for the parts. Any suggestions would be appreciated!
  • Anonymous Mar 07, 2008
    We also have a DVD stuck in the player. Happened practically when the TV was brand new! What can we do?
If you purchased it at Costco, I would recommend contacting their Costco Concierge service. They facilitate repair requests. They told me that the TV was not repairable and gave me a full refund after I owed the TV for 1 1/2 years
Posted on Jul 26, 2008
We've been ripped off! I've learned my lesson about "Mintek" have you?
Posted on Jul 03, 2008
You have to open and remove the disk then push in a post card the size of cd disk then try the source button change it tv mode.
Posted on Sep 06, 2008
Our Mintek HDTV Mod# DTV-323. WIth an internal DVD Player keeps comming on when it is in tv mode. there is a disc hung in it. It has not worked for a long time. How do I fix this problem or can the dvd...
2 answers 1 usually you can remove a stuck disk by finding the tiny pin hole on the dvd insertion tray and pushing it in about 1/2 inch this will force open the player so you can remove the stuck bootleg dvd you put in it. step 2 is you can unplug the tv lay it face down and remove the stand and the back screws from the tv there about 20 screws once removed you can pll the back off the TV and find the dvd module and carefully disconnect the moduler plugs connected to the dvd
Feb 20, 2018 | Mintek DTV-323 32 in. LCD TV/DVD Combo
Not reading disk in player (mintek 1760)
Try a wet lens cleaner from any good audio or video store.
Good luck
Rich
Jun 06, 2010 | Mintek MDP-1770 7 in. Portable DVD Player...
Dvd is stuck in player - won't play and won't eject
open cabinet of your dvd you will find out a lock open that pick up your disk during proseeing that is stucked
Mar 05, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
I have a mintek 2580 DVD player with a rented disk in it that won't open
If you remove the top of the player you can manually eject the disk.
Oct 20, 2009 | Mintek DVD-2580 DVD Player
Dvd player not reading disk
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 21, 2009 | Mintek MDP-1770 Portable DVD Player
I am unable to find tech support for a Mintek hdtv
It does not appear you will find them. The last time their web page was active was in August 2007. =>
http://web.archive.org/web/*/http://www.mintekdigital.com
They had a recall of portable batteries and a lawsuit on infringement. The parent company is Jiangsu Digital Technology Co., Ltd. ("Shinco Digital").
The website is down and the phone numbers don't seem to work. Last known address.
Mintek Digital Inc. Private Company, Headquarters Location
4915 E Hunter Ave., Anaheim, CA 92807, United States
(866)709-9500, (714)777-3090, (714)777-5933 fax, http://www.mintekdigital.com
Jan 03, 2009 | Mintek LCD TV Progressive Scan DVD Player
My mintek dvd player says no disk
Dec 07, 2008 | Mintek MDP-1815 Portable DVD Player
Mintek 2110 no component video
You need to change the Video out in the menu.
Press set up on the remote
move down to video out and select YUV output
it should now work
Aug 08, 2008 | Mintek DVD-2580 DVD Player
Dvd stuck in player. Dvd won't play. None of the buttons works. Nothing works. Can't watch tv or anything.
Had the same problem. After a couple of times of removing the DVD player and manuelly removing the DVD I called for a RMA and they fixed it, but they say the problem was that  I had another DVD in the player. ???
Oct 16, 2007 | Mintek DTV-373-D 37 in. LCD HDTV
Mintek DTV-263 26 in. LCD Television Logo
284 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
