Question about GE JVM3670 Microwave Oven
No Power my wife ran it 30 mins with nothing in it...now no power. Is there a fuse?
Température exhaust monte
Posted on Feb 22, 2008
  • 2,130 Answers
Yes there is a fuse. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
Please let me know if I can be of further assistance to you.
- Jim
Wife ran for 14 min w/out anything in it changed fuse no luck
You need to change the cavity thermostat. The unit got too hot and blew the cavity thermostat. If this is a vent-a-hood model, it will be up under the vent housing at the top (must drop microwave to change) and if built-in, it will be on the left side under the outer cover. Just remove the screws from the back and sides and right along the edge along the bottom sides. Will have 2 wires going to it from each side. Just replace thermostat and reattach molex plugs. Then retest. Should be fine after that.
Jul 12, 2010 | LG LMV1630 Convection/Microwave Oven
Microwave was ran for 5 minutes with nothin in it now no display
most have an internal fuse check it first if that is not it check the thermal fuse both parts run 10-15 dollars
Jun 30, 2009 | Maytag MMV4205 Microwave Oven
I have a GE JE 1860. Someone ran the microwave for 15 minutes with nothing in it. Now it doesn't work at all , no power, no lights, nothing. Is there a fuse that may have gotten burned out? Is this...
There is a fuse and cavity thermal fuses as well as one on the magnatron that is supposed to reset itself.. The fuse is behind the control panel and the cavity fuses will require removal of the cabinet. Did you check for power at the plug?
Eric
Jun 20, 2009 | GE JE1860 Microwave Oven
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
2 year old ge profile spacemaker Microwave lost all power
Inside unit is a cylinder fuse which can blow for a number of reasons. External cover needs to be removed to access. If you are confident in doing this and can find & check the fuse then it would be my first guess. If fuse is OK then you will need to have repaired. If fuse isblown & you replace then it blows again,you will need to have repaired. regards
Jul 25, 2007 | GE JVM2070 Microwave Oven
GE JVM3670 Microwave Oven Logo
207 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
