Question about LG (GDR8163BB) (gdr8163bb 10pk) Internal DVD Drive
DVD drive doesn't open. DVD is inside. - LG (GDR8163BB) (gdr8163bb 10pk) Internal DVD Drive
  • 218 Answers
Switch off the pc. Look closely on the CD tray face plate. You will see a small pin hole. Insert a needle or pin through it and press. The tray will open.
Posted on Feb 09, 2010
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray, close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Dvd drive issues
There may be an issue with your Lazer. Open the DVD drive and get some Nail polish. Gently wipe the lazer inside the drive and then wait for it to dry almost instantly. Try the disk back in. If this doesn't work the best thing to do is contact your Manufacturer " Asus " and check to see if it is under warranty.
Sep 24, 2012 | ASUS K53E-1BSX Core i3-2310M 2.1GHz 3GB...
Dvd door doesn't open
if there is a small hole on the panel of your dvd drive push a straightened paper clip inside until you feel it press down this will open up the drive
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrative tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
hope this helps
Sep 24, 2012 | Computers & Internet
TOSHIBA R10 CD DRIVE DOESN'T OPEN
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if there is a small hole on the panel of your dvd drive push a staightened paper clip inside until you feel it press down this will open up the drive
hope it helps
Apr 30, 2012 | Toshiba Computers & Internet
MY id58 GATEWAY DVD PLAYER, i cant insert a disc because blocked by the mechanism eventhough there is no disc inside.
There is a small hole on the front of the drive. Use a paperclip or a safety pin in the hole to push open the disc try enough to pull it open the rest of the way with your hand. Insert the disc, press the button on the drive to close the bay. If the tray doesn't close gently push the tray back in. If no lights blink on the front of the drive, the drive may be unplugged or has gone bad.
Jul 06, 2011 | Computers & Internet
I recently acquired a used Dell Optiplex 320 desktop computer. When I lay the computer flat, the dvd drawer will open and function. When I stand the computer upright, the dvd drawer will not open. I am...
Sounds like there's something stuck inside the DVD drawer that blocks the drawer from opening if it's not its side. Try turning it over onto the other side, just for a minute, and see if it opens. If it does, there's something blocking the drawer. If it doesn't, you'll probably need a new drive, as that one's literally worn out...which I've only seen twice.
Jul 04, 2011 | Dell Drive for Dell OptiPlex 320...
Describe how you insert a dvd into a laptop
Hi Eunice, just want to clarify, for lenovo notebook if it doesn't have DVD drive you can use external DVD drive to access DVD CD. DVD external drive is just plug and play device once attached in your USB port, it will automatically detected and once detected you can use it already. Just install Burner application to burn some files if your DVD is capable of burning CD.
Jun 22, 2011 | Lenovo 3000 Y410 (59012354) PC Notebook
The door of my Toshiba sd-6100 dvd player will not open. There's a dvd inside and it will play but it will not eject. How can I open it manually?
Try unplugging the DVD player from the outlet for 2-3 minutes to reset the unit. If this doesn't help, the player probably needs to be serviced.
I hope this helps.
(if the unit is out of warranty, you could try opening the case and removing the DVD drive. There should be a manual ejection button hidden on the front of the drive. Unfortunately, doing this to get your DVD out voids the warranty, if it is still under warranty. Each manufacturer puts this button in a different place. On computer drives, the faceplate has a hole to indicate the spot. The ejection usually takes some force with a straightened paperclip (or small allen wrench).)
May 12, 2011 | Toshiba SD6100 DVD Player
LG (GDR8163BB) (gdr8163bb 10pk) Internal DVD Drive Logo
83 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
