Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Will not spray water or cleaner. Belt seem to be good. how do i test the pump?
  • 701 Answers
Are you sure the pump belt is not stretched? It is hard to tell, but if it is it won't pump.
Posted on Feb 11, 2010
Eco steam mop no steam
see this causes and use the common sense. God bless you
nspect your steam cleaner's belts for loss or damage. Damaged belts can cause the brushes to stop rolling or the spray mechanism to stop functioning. To fix a damaged pump or brush belt, first unplug the steam cleaner. Refer to the user's manual to determine the specific location of each belt. Order a new belt directly from the manufacturer's website, or from a local home improvement store, if necessary.
Sep 19, 2012 | Vacuums
Machine w/not squirt
have you check the spray nozzle or spray line for s clog? only other thing you didn't list? let me know?
Aug 23, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
The belt has broke on the cleaner is that the reason why the cleaner is not running water out or sucking up any water
There are two belts and they drive the pump that sprays the water out, so if one is broken or loose, you will have poor function.
Dec 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Proheat is not spraying water. What is causing this? and will it be expensive to fix?
It is very simple and inexpensive to fix. All you need to do is replace the pump belt. Here is the belt you need:
Bissell Proheat Pump Belt
May 20, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water won't spray out of the cleaner
If it won't dispense water then that means that the pump belt needs to be replaced. Here is the belt you need:
May 22, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Unit is not pumping water out
This is most commonly caused by the rubber belt being broken, as the belt powers the main pump.
Check the belt, (through the access door on the side of the machine,) and if it appears worn or stretched, (or is broken or absent,) replace it.
Otherwise it could be a problem with the pump, or could be soap clogging the main water lines. Try flushing the water lines out with warm water. A good way to see if this is the problem is to try using the hand tool. If the hand tool sprays water, the problem is most likely not the pump. If it doesn't, it is probably pump-related.
-R
Jul 31, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell
Check the pump belt, just take that small door of and you can see the belt. If it looks ok, then probably need a new pump.
Jul 16, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Feb 25, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
416 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
