Question about Maytag Dryers
The dryer puts off a chemical smell on the clothes-gas dryer
  • 447 Answers
If it smells like gas on your clothes, your exhaust vent is probably being restricted, causing the exhaust to back up into the dryer cavity. Remove exhaust hose, make sure it is clear all the way to where it exits your home.( sometimes birds build nests in the outlet vent) Look into vent where hose attatches to dryer, and make sure it is clear also. If you smell gas when moving the dryer, there should be a shutoff valve near the wall, close it. DO NOT THE DRYER ! ! Call someone qualified to make the repair.
Posted on Feb 09, 2010
Clothes come out of my gas dryer with a slight chemical smell
In my years of experience, the only situation like this resulted when painting had been done within the last 12 months. The flame burns off the VOCs. Beyond that, it's a stumper.
Apr 20, 2014 | Maytag MDG2706A Gas Dryer
Washed clothes with gasoline on them. Put into dryer now washer and dryer smell like gasoline. How do I get it out?
To remove gas (petrol) smell from clothing, soak overnight in baby oil (use like you would downy), then wash in baking soda, then wash with normal detergent. It will rid "gas smell" from an entire basket of clothes. Air Dry ONLY
From ehow website:
Step1
Buy a bottle of baby oil. Since gas is an oil based product it is going to take an oil based product to clean the gas out of your clothing. Baby oil is a great product to use as it shouldn't, in most cases, cause further damage to your clothing.
Step2
Soak your clothes with a bit of laundry detergent, water, and a generous portion of baby oil. Also dab some right on the stain before soaking.
Step3
Swash your clothes in the water for a while and let them sit for about five minutes. Transfer the clothes into your washer, once again remembering not to mix them with any other clothing, and let the cycle finish.
Step4
Wash the clothes. If you have a top load washer, let it partially fill up about 1/4 of the way with water. Put some of the baby oil in the wash with the clothes and swash it around a bit. Once the washer cycle begins, add the detergent and let the cycle finish. Make sure that your gas coated clothes are the only clothes you put in the wash.
Step5
Dry your clothing. Make sure you only AIR DRY on a clothes line these clothes. It could take more than one wash to get all the oil out of your clothing. If you use the dryer after the first, or even the second time, you could risk starting a fire in your dryer.
Step6
Check and see if any smell remains in your clothing. If the smell of gas remains on the clothing repeat the wash with baby oil again until the smell is gone.
Sep 04, 2011 | Frigidaire Electric Dryer
Chemical like smell while clothes are drying
If you have recently painted or varnished something then just air out the house. The fumes can react w/ the heat of the dryer to create this smell. It smells different than the actual fumes, but still like some sort of solvent.
Jul 20, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Burning chemical smell coming from the gas dryer
You first thought was probably the correct one...the fumes from the new paint may take a few days to disspate enough not to react with the heat of the dryer...I would give it a few dyas to clear before looking any further...
heatman101
May 28, 2010 | Kenmore Elite HE4 Electric Dryer
Smell after drying
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet.
If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others.
You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
Dec 16, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Nov 11, 2008 | Maytag MDG2706A Gas Dryer
Maytag dryer smell of gas inside and venting
hi thanks for the question you don't have a problem if you smell the air going out of the house it will have that smell thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
FUEL LIKE ORDER COMING FROM ELECTRIC DRYER POWERE BY FUSES
Have you recently painted anywhere in your home. And I mean anywhere? Paint fumes or other chemical type cleaners or solvents will get in the elements and put off that whole gas or oil smell. If no, have you put any type of clothes in the dryer that may have had some paint or anything else petroleum based on them to dry. That also could have caused this smell as well. If your hot water heater runs on propane or natural gas, check it careful for leaks. This could be a serious situation as a major explosion could happen if it is leaking. Leave the house and call 911 immediatly from a safe distance. I doubt that this is the problem, but be safe than sorry. Let me know if none of these are the culprits. Thanks and let me know.
Feb 22, 2008 | Whirlpool LER5636P Electric Dryer
ELECTRIC DRYER SMELL LIKE GAS
I would imagine that you are saying you have an electric dryer, but it smells like it has a gas leak correct? Let me ask one question, have you used any kind of paints or chemicals in your house lately? If you have painted anything (in any room as well), the fumes of that paint (or other chemical) will get into the elements, and produce that smell for sure. I have actually had customers give me the clothes they dried to smell them, and sure enough, it will get in the clothes for sure. If this isnt the case, be sure that you dont have a gas line behind the dryer that may be leaking, or if your hot water heater or furnace is gas, you dont have a leak there. If you do have gas coming into your home, and you havent painted, etc, call your gas or propane service provider IMMEDIATLY from another home or location and let them come out to be sure you dont have a hidden leak. Good Luck!!!!!
Jan 31, 2008 | Dryers
Dryers Logo
185 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
