Question about Malber WD1000 Front Load Washer/Dryer
I have Malber WD1000. Hot water run through the pipe, but do not fill machine. How can I find and check the filter of hot water in machine
  • 10,865 Answers
Hello. Just turn off the water and then remove the fill hose which goes from the water faucet into the back of the machine. Examine the entire hose and pay closest attention to the filter located at the end of the hose nearest the faucet. regards, Joe
PS - please rate my answer as helpful Thank you.
Posted on Feb 08, 2010
I have the Malber WD1000,the wash cycle goes on but no water pumps out, a couple drops come out . How do i fix it?
No water fill
1.water valves closed----turn on valves
2. Hoses kinked---unkink hoses
3. Screen in fill hose clogged----clean out screen
4. No power to fill solenoid---replace solenoid
5. Faulty water level control---replace control
6. Machine did not turn on----check control & power outlet
Water will not drain from machine
1.kinked or clogged hose----clean drain hose
2.pump does not run----readjust & tighten pump-drive mechanism
3.suds lock----remove suds,, add cold water
4.faulty transfer valve---replace
5.defective timer----replace
6.loose belt---adjust belt
Sep 22, 2011 | Malber WD1000 Front Load Washer/Dryer
Hi, How do I open the door on a Malber wd1000 when is it stuck after the cycle is over?
Some machines require it to be empty of water to allow the door to open.Try dropping the drain hose low into a bucket to allow it to open, then clean the filter as it may be blocked causing this problem... Good luck
Feb 10, 2011 | Malber WD1000 Front Load Washer/Dryer
Does not get in water not spining
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"> </span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips&hellip;</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"> </span><br /><span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt; mso-ansi-language: EN-US; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><br />Washing Machine Problems No Water<br /><a href="http://www.fixya.com/support/r3880845-washing_machine_problems_no_water" target="_blank">http://www.fixya.com/support/r3880845-washing_machine_problems_no_water</a><br /><br />Washing Machine Fix Washing Machine No Water<br /><a href="http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no" target="_blank">http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span>
Aug 26, 2010 | Malber WD1000 Front Load Washer/Dryer
WD1000 has too much water
You are not hooked up to the drain properly. If you do not create a trap the water will drain back into the machine. The drain tube goes from the bottom of the machine up to the top and then back to the bottom. You need to run the drain tube up to a final drain or other trap. You can even create another mini trap by making a loop before running into the drain. Whatever you do just try to get the hose to go about as high as the highest point at the back of the machine, but not higher, as it will create a siphon and flood the machine.
Jan 24, 2010 | Malber WD1000 Front Load Washer/Dryer
I lost manual . there are a lot water inside. how
To get the water out , bring the machine forward
Take the drain hose out of the waste pipe
Remove any clips holding it to the back of the washer
Lower the hose into a bucket and the water will drain out under gravity
As for the knob it is a replaceable part but you will need to contact Malber
Nov 13, 2009 | Malber WD1000 Front Load Washer/Dryer
Water overflows from the soap dispenser drawer when filling tub
Hello, the problem here is you have a blockage between the soap dispenser and the tub, remove the top of the machine, Normally 3 screws at the back lip of the machine. Now you have access to the soap dispenser. There is a pipe that runs from the dispenser to the tub, remove this pipe and inside you will most likely find a sock or similar item of clothing. Put everything back together and you are all set. Good Luck! Mike
Nov 01, 2009 | Malber WD1000 Front Load Washer/Dryer
Water in drum after turning off
could be a leaking fill valve ..not shutting off good after shutoff
Dec 08, 2008 | Malber WD1000 Front Load Washer/Dryer
How long can drain run be
no the pump cant handle the extra length in the hose
Aug 25, 2008 | Malber WD1000 Front Load Washer/Dryer
No hot water flow
The hot water valve may be broken.
Apr 26, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
93 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
