Question about Kitchen Ranges
Kenmore electric oven, broil and bake will not work. Tested power and it is ok. Top burners all work. Stove is 2-3 years old.
  • 102 Answers
Check continuity of the broil/bake selector, it might be faulty
Posted on Feb 08, 2010
We have an 8 year old Frigidaire electric range. When going to use the oven a few nights ago, we discovered that neither the top or bottom oven burner was heating at all - tired both Bake and Broil. The...
You will have to check that the switch is is working ok , with a vault meter check for voltage at the burner , if none check at the switch and so forth back to the wall switch, if there is vaults at the burner it is faulty .
May 27, 2017 | Frigidaire FEF339E Electric Range
I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
May 12, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
bad oven ignitor is the most common cause of bake failure, located onthe side of hte burner bar itself, if youd like with a multi-meter, you can check the wires leading to the ignitor for 110v. if you have power and nothing was glowing from ignitor theres your problem
Nov 23, 2008 | Kitchen Ranges
TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
very likely your oven control it does those things without any input from the oven so if it doesnt do what it is supposed to it is likely bad
Aug 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kitchen Ranges Logo
165 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
