Question about LG WM1815CS Front Load Washer
How do i find the drain pump in my lg washer" Problem Now!
  • LG Master
  • 8,220 Answers
The drain pump is right behind the pump filter on the base of the washer. You must remove the top then the front panel to get to it.
I have a manual HERE which shows how to
Posted on Feb 09, 2010
The washer stops at 39 minutes on a regular wash cycle and the code OE is displayed
This fault code can mean that the pump is faulty as well as blocked, first of all check for a blockage and, if none is found then the likelihood is that the drain pump is faulty. Should you need it, the most common drain pump used on LG washers and washer dryers is this one.
On non-display panel models this fault code is denoted by the lights for 800, 500 and No Spin being lit or flashing.
  • Check pump filter is clear and there are no obstructions
  • Check the drain hose for obstruction
  • Check the drain hose is not kinked
  • Check the drain pump filter and clean if required
  • Check the air chamber and pressure sensor hose
  • Check drain pump, normal resistance is 152-175?
  • Check drain pump rotor
  • Check connections to water drain pump
Oct 09, 2015 | LG WM2701HV Washer
My LG front load washer won't drain model#WM2050CW how can I fix that?
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Mar 14, 2015 | LG Washing Machines
Why won't my LG washing machine pump out water?
Sep 10, 2014 | LG WM2688HWM TROMM SteamWasher
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
My LG washer wm2277hw does not drain water and
either drain pump itself is broken or something jammed in between the pump housing and pump impellor. the drain hose itself or pump cleanout cup (behind lower left access panel) may be clogged too.
Mar 26, 2010 | LG WM-2277HW Front Load Washer
LG front load washer does not drain after cycle. Motor runs,drum moves forward and reverse but seems pump doesn't pump. Drain hose clear as well as filter area.
Check for 120 volts to the pump motor while in drain mode, if the pump does not run, or just hums, replace the pump motor. Some LG's have both a recirculating and drain motor on the pump casing, so be sure to replace the correct motor.
Dec 30, 2009 | LG WM-2277HW Front Load Washer
Lg wm3677hw combo washer drain pump repair question
You replace the whole drain pump. Pretty easy to do from the opening in the bottom by resting the unit on its back. (Make sure you drain the unit completely) You should be able to get the drain pump (pt #4681EA2001D) from http://www.encompassparts.com/lgconsumer/ for less than $50 + s&h.
Aug 31, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG WM1815CS Front Load Washer Logo
628 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
