Question about Dell Inspiron 1525 Notebook
The buit in sd/mmc card is not able to read on dell inspiron 1525
The buit in sd/mmc card is not able to read the sdhc card on my dell inspiron 1525..which it was able to previously
    Novelist:
  • 132 Answers
Try to do system restore,
If that doesn't work download the latest driver for that built in card reader then install it,. if it still doesn't work run the hardware diagnostics of the computer then if it passes without any error you'll need to do operating system reinstallation so that means erasing everything in the computer,.. If that doesn't solve your problem get that card reader replaced.
Hope this helps!
Posted on Feb 12, 2010
Mi laptop Dell Inspiron 11 z no reconoce la tarjeta SD
  • Maria, the reader only reads the cards listed below. try another card to see if it reads another. If you open My Computer does the system see the card from that area?
  • The 7-in-1 Media Card Reader reads the following memory cards:
    • Secure Digital (SD)
    • MultiMediaCard (MMC)
    • Memory Stick (MS)
    • Memory Stick PRO (MS-PRO)
    • xD-Picture Card (xD)
    • MMC+
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 02, 2014 | Dell Inspiron 11Z Laptop Computer (Intel...
Amilo pi1505 will only read sd card not sdhc
Correct. The PI1505 will work with SD cards but not with SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You can get a SDHC-compatible card reader which plugs into the USB port.
Dec 31, 2012 | Dell Inspiron E1505 Notebook
SD/MMC card is not getting detected. SOmetimes it works but sometimes it doesn't please advise.
I would like you to check www.dellsupport.com for some updates which you can download for the card reader and motherboard bios, and its chipset. kindly update these devices. if all fails then card reader needs replacement.
Mar 22, 2011 | Dell Inspiron 1525 Notebook
How do I format a 4MB SDHC card for this camera
"SD and MMC flash memory cards marketed by Kodak, Kingston, Sandisk, PNY and other flash-memory card manufacturers will work with the EasyShare C643. The digital camera supports standard MMC cards and SD (secure digital) cards, but not SD High-Capacity (SDHC) or SD Extended Capacity (SDXC) cards."
Read more: Compatible SD and MMC Cards for a Kodak EasyShare C643 ' eHow.com http://www.ehow.com/facts_7590028_compatible-cards-kodak-easyshare-c643.html#ixzz1BijGdWKF
Jan 21, 2011 | Kodak EasyShare C643 Digital Camera
Computer-challenged person can't find memory slot
Hello
Thank you for using
FixYa for your problem
There is a little plastic thing in the front part of the unit. push this and it will now come out, now you can put in your SD/MMC memory card
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | Dell Inspiron 1525 Notebook
I insert a sd/mmc card in the slotwhich is same as
Sounds like the drivers might be missing which is why there is no response.
Depending on which operating system your running on the laptop will determine what file you download.
Go to this page:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=VOS_N_1500&os=WLH&osl=en&catid=&impid=
Choose your operating system, either XP or Vista and then under where it says chipset choose Ricoh Driver and download now. choose download by internet browser. Save it to the desktop if possible and then run the file so it installs.
If you go thru installing the drivrr and the card is still not being read by the laptop then the motherboard is bad.
Aug 22, 2009 | Dell Vostro 1500 Notebook
Kingston 4gb sd card won't read
I had a problem with lenovo's reader like this, because i put in the nokia 6600 card, correct format and all, but apparently too old and not yet ment to be read by a computer ...
sd could still be hc ... the system of names is still not set up right. if you got a small black attachment for the card that makes it longer, put it on and try inserting the card again.
check if all the drivers are like they should be.
if you've got a friend with a card reader, make sure the card is ok. and if you've got a friend with a card, make sure the reader is like it's supposed to be
post a feedback, ok
Feb 23, 2009 | Dell Inspiron E1505 Notebook
How can i use sd/mmc memory card reader on my laptop? ia am using dell inspiron 1525 model?
The SD/MMC memory slot is already configured to read standard and HDSD cards. Just remove the DELL blank from the slot by pushing it in until it clicks and release it. Then pull it out. Insert the SD/MMC card into the slot and push it in until it clicks. The DELL Blank is shorter than an actual SD/MMC card, so don't try to push the SD/MMC card any further than the 'click'. Remove by pushing in until it clicks, release, remove.
Jan 10, 2009 | Dell Inspiron 1525 Notebook
Accessing info on an SD card from a computer
Is it only specific cards that you can't read on it? I am assuming you're trying from the internal card reader. If it will read 2 Gigabyte or less cards, and will NOT read cards with more storage space, it's because SDHC, the format that allows more than 2G on a SD card, is a different format, and most older card readers will not work with SDHC.
You can purchase a SDHC reader that works in the USB port from your local electronics store or Office supply store.
Jan 01, 2009 | Dell Inspiron 1525 Notebook
Inspiron 1525 sd/mmc card
goto www.dell.com enter your service tag which is on the underneath of your laptop and ya should be able to download it fron there.
Dec 15, 2008 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Notebook Logo
637 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
