Question about Sony Playstation 3 (PS3) Console
Ps3 gives error 80010514 - Sony Playstation 3 (PS3) Console
    Problem Solver:
  • 10 Answers
This is a common error........this error occur due to the internal defect caused by crashes in the cdyou used
you can fix this easily don't worry .......... their are repair guide availablefor Sony Ps3 you can download it and solve your problem just like that ......Click this link
CLICKHERE to download guide
Posted on Aug 23, 2010
  • 60 Answers
80010514 - Disc error detected. Retrying operation.
Posted on Feb 09, 2010
4 Suggested Answers
CLEONTI
  • 33 Answers
SOURCE: 80010514
Unfortunately this is typically due to a fault in the PS3 - most likely a problem with the Blu-Ray drive. Sony should send you a box to mail it to them and then it can be repaired if you are still under warranty.
SCEA Consumer Services
1-800-345-SONY (7669)
Monday - Saturday 6:00 AM - 8:00 PM PST
Sunday 7:00AM- 6:30 PM PST
If you appreciate the time I took to help with this, please take the time to rate my response.
Hope this helps,
Chris
Posted on Mar 24, 2009
urbanhookupz
  • 213 Answers
SOURCE: how di i reset my ps3
read this article:
“An error occurred during the start operation. 80010514′
Gamerevolver.com recently ran into the the dreaded 80010514 error shortly after installing a new game they had purchased off the PlayStation Store and decided to document it. Here is what the have to say…
Since this error occurred, we obviously contacted Sony Support. We were informed that the code is not common, and a simple reset of the system, and restoral of factory settings should do the trick. Unfortunately, after the restoral, the error still occurred.
The error code is actually one of two things, a) a faulty sector on the internal hard drive, or b) a faulty installation of software/firmware, both iterations actually coincide with eachother. If the hard drive suffers a faulty sector ( a section of damaged space on the drive that data may have been written to that no longer is readable), an installation may still be processed, and even work, but the error can cause some serious side effects, such as option b. If your PS3 has installed an item incorrectly, including firmware, it is in high risk of receiving this error.
Basically, what is occuring is the corruption of game disc recognition and execution. If you will notice, in 90% of all cases, the drive will still play DVD and even Blu Ray movies with no problems. When trying to start a game however, the title, sooner or later, will receive the error.
1) Ensure that your internet connection is stable. If you are using a wireless connection, make sure your signal is at least a solid 80%. If not, make the proper adjustments until it is.
2) Dust your machine regularly. Any PS3 owner will tell you that the Playstation 3 is a dust magnet. Just run a dry cloth over it every couple days, and you should be fine. This will help prevent heat issues and shorts that may occur.
3) When installing firmware and/or software, make sure you follow the instructions. Even if you have installed 6 versions prior, each one is different, and may require additional steps. Save yourself the headache and just follow them, it only takes a minute or so longer to do it right.
Lets sum it all up, the error is not hardware related and is caused due to corruption of firmware. Restoring you PS3 will not roll back the firmware, and unfortunately will not fix the issue 9 times out of 10. If you are receiving this error, contact Sony for a replacement unit. Again I hope none of my readers have to see the dreaded 80010514 error and by following Gamerevolver.com’s simple steps your bound to prolongue the life of your PS3 indefinitely.
(Update) Eurogamer.net contacted a SCE UK spokesperson which told them “”I’ve spoken to our Customer Services department and they aren’t aware of this issue with the PS3.” So take that as you will? Is the dreaded 80010514 just a myth? or an error that Sony is not aware of?
(Update 2) Try this before replacing Blu Ray drive (Last Resort)
Undertakerza updated a game, Warhawk and his system froze, got it rebooted it could no longer access any discs (cd, dvd, blu ray, games) he was ejecting and re inserting disks when I realized that the drive wasn’t making any noise and also … not spinning disks anymore they come out the exact same way he put them in.
Here is how he did it:
Ok so I’ve fixed my issue. I will run through what you will need to do to fix yours if you are having issues with the blu-ray drive and general PS3 system operations like the XMediaBar this is totally worth a shot … I doubt this will fix any other issue. If not then your blu-ray drive/ PS3 is probably dead and needs replacement via the method listed above or by sony.
If you can, I suggest you back up your PS3 first. The menu that you will access to can fully erase your PS3 if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
The current version of the ps3 firmware has a “recovery console”.
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options (I have attached a picture of this screen below)
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive.
However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory which is corrupted thus fixing the problem
UPDATE: With the new firmware 3.10 you may be able to report the error code directly to Sony via your PS3 console. Have a look here, please note that this has not been tested for this error code yet.
Posted on Apr 10, 2010
  • 85 Answers
SOURCE: Ps3 error code 80010514
This is alot of info but you wanted to know. :P hope it helps
Gamerevolver.com recently had an interesting article regarding the dreaded 80010514 error. I hope many of my loyal visitors never have to encounter it. Their is a known issue with the PS3, simply known as error 800010514 which doesn’t happen often but when it does, it’s darn right nasty.
The error in question is mainly seen within the first month of use, or to put it bluntly, it has the error right out of the box, however, we have seen this occur at almost a year into service as well.
You access it by
Posted on Apr 28, 2010
Go to this link as it has nice info on how to repair the problem. Its too much to list here. :)
http://www.ps3errorcodesfix.com/ps3-error-code-80010514
Sep 15, 2012 | Sony Playstation 3 (PS3) Console
For some reasom my ufc2010 all the suden wont play and gives me a error code of 80010514 can anybody help me
Hello Chadhughes20,
You can read further regarding this error by clicking the link below:
http://www.ps3blog.co.za/2008/04/10/ps3-error-80010514-explained/
Thank you,
Jack
Feb 17, 2011 | Sony Playstation 3 (PS3) Console
Error cod 80010514 ps3
the PS3 error code 80010514 is related to an error with the Blu-Ray disk drive inside your PS3 console
Nov 03, 2010 | Sony Playstation 3 (PS3) Console
FIFA 11 game wont start (PS3) gives me error code 80010514. All other games work fine. Game works fine in brothers PS3. Never had this problem before. PS3 support says they have had a lot of calls with...
It's eiyther one of two problems:
The first is that FIFA 11 is screwed up due to an EA Sports programming glitch within the game - (see http://www.community.eu.playstation.com/t5/Technical-Help/FIFA-11-Error-80010514/m-p/11614173))
OR
The second is that your PS3 is dying and the laser won't read discs. Which gets progressively worse, or so i've read. - (see http://www.ps3blog.co.za/2008/04/10/ps3-error-80010514-explained/)
I'm getting the same error but my PS3 isn't yet 12 months old, so is going back to the store.
P*ssed that I can't play the new FIFA though!!!!
Oct 02, 2010 | Video Game Consoles & Games
My ps3 gives me two error: 80010514 and 8001002B, I tried it all.
go under settings then system settings then restore default settings
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Error 80010514
this is a startup error, give sony customer care a call, they replaced mine for free even out of warranty with this error.
Jul 15, 2009 | Sony Playstation 3 (PS3) Console
Ps3 does not read anything blue ray?will play reg dvds?
80010514
"Sony has confirmed that 80010514 is in-fact a hardware failure - In particular the Blueray drive has failed and this system can not function like this"
In other words you PS3 is malfunctioning call Sony and arrange a replacement to be sent, Unfortunately there is no quick fix and any attempt to do so will void your warranty.
Give Sony a call they are very helpful
Hope this helped
Blazamane.
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
PS3 ERROR 80010514
firmware 2.0?Is a bug.....or lens by throwing
Jun 21, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
375 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
