Question about Gateway 700 XL (700XLDFM) PC Desktop
TRIED TO HOOK UP SPEAKERS STATIC IN THE LINE - Gateway 700 XL (700XLDFM) PC Desktop
  • 36 Answers
Ythgfhfgh
Posted on Feb 10, 2010
Low to no sound on Media Mate satellite speaker. How to troubleshoot. Powered speaker works fine. Limited volume on accessory speaker. Already tried swapping cables and tried on another system. Same...
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 05, 2011 | Bose MediaMate Computer Speakers
Get loud hum from both bose companion II speakers when i disconnect left speaker hum goes away tried most everything else thanks
try swapping the speakers around if the problem still persists either the speaker is faulty
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 23, 2011 | Bose Companion II Computer Speakers
My speakers are plugged in and they don't work. if i hook them up to my son's mp3 player they do, but as soon as i hook them up to the computer they dont
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 20, 2011 | Labtec AMX 2000 Computer Speakers
Front speakers work but only a ticking sound from the rear speakers?
try swapping the speakers around if the problem still persists either the speaker is faulty or
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Mar 22, 2011 | Altec Lansing ADA745 4 Speakers
I just bought the Creative T40 II series speakers. The main speaker (R), the one with the power and controls works just fine, but I'm not getting anything from the secondary speaker (L). I've tried...
hope this helps
don
Feb 21, 2011 | Creative Technology Gigaworks T40 2...
Right speaker not working
hope this helps
don
Feb 18, 2011 | Dell A225 2 Speakers
Why does my left speaker sound extremely static?
hope this helps
Jan 31, 2011 | Philips SPA1312 2 Speakers
Problems with my computer speakers
Check to see that you have plugged the speakers into the correct output jack. The jack should be color coded green. The other jacks are line-out and microphone. If you plug into the line-out, you will usually only get a hum or static
Jun 23, 2009 | Gateway GMAX 5100 Computer Speakers
How to hook my altec lansing speakers to my TV? and my laptop @ the same time
You can do this through a receiver (like a stereo receiver). Hook the tv up to line 1 and the computer up to line 2, then hook the stereo receiver output to the input of your subwoofer. Then shift the receiver from line 1 to line 2 (as easy as pressing a button on the front of the receiver) to hear either one through your speakers.
Nov 26, 2008 | Altec Lansing ADA 885 Computer Speakers
I don't know how to properly hook up to an HP m9060n computer.
you must connect the cables, and configure the pc yo work with it.
you must configure pc according with the cables/setup you connect.
Nov 27, 2007 | Altec Lansing ADA 885 Computer Speakers
Gateway 700 XL (700XLDFM) PC Desktop Logo
22 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
