Question about Onkyo TX-DS575 Receiver
When changing input, or making any changes it turns off.
    Brigadier General:
  • 8,546 Answers
Do you mean with the remote or without? If only the former, I'd suspect the remote.
If it happens with front-panel controls, too, what selections cause the failure and how are they connected?
If a specific source selection causes the problem, what happens if you disconnect the device on that input?
Details...
Posted on Feb 09, 2010
Mitsubishi tv- sony 1030 avr hdmi connection no picture
Just to clarify. You have the proper inputs selected on the TV and the proper output on the reciever?
Jan 24, 2013 | Mitsubishi WD-Y657 65" HDTV
I cant keep my tv turned on after i pushed the rgb button by mistake it keeps on displaying no signal and then it goes off
Turn on the TV again. You need to change the input from RGB back to cable or HDMI or Component or whatever input you have a source for. If you don't know which one, look at the back of the TV and the wires you've got plugged into it.
If it's 1 round coaxial cable, change the input to Cable.
If it's three wires (red, white, and yellow) change the input to A/V.
If it's 5 multicolored wires, change the input to Component.
If it's an HDMI cable, change input to HDMI.
If you cannot change the input before the TV turns itself off, try unplugging the TV from the wall socket for about 10 seconds, and then plugging it back in. If its still on RGB, you're going to have to either find a way to get faster at switching inputs, or find an RGB cable and something to connect it to your TV. This is a last resort however.
Jun 09, 2011 | Televison & Video
TV changes from input setting to channel 3 when turned on.
you need a service repair, on that ckt there's an IC function as memory IC replace that part and all your program well be stored. can found that ic most likely near switch botton area 4 or 8 pin IC.
Mar 03, 2010 | Apex Digital PF2025 20" TV
TV does not turn on, it only makes a ticking noise.
Sometimes the input, or source has been changed without your knowledge. Try to change the input button either through the remote, or directly on the monitor. This should rotate you between the snow screen, cable and another input screen. One of them should be moer than just the black screen you see.
Jul 05, 2009 | JVC LT-47P789 47 in. LCD HDTV
I can't work out how to change the default input Sony KV-24WX1U
Don't think it can be done,you'll have to change it manually or it should go to AV1 when you turn on the cable decoder.
Jan 08, 2009 | Televison & Video
No signal
mine did the same thing...it was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Jan 04, 2009 | Vizio L32 32 in. LCD HDTV
How do I change to the front inputs to play video games w/o the remote?
There should be a button on the frame of the TV that say's input. or Source, Press that button until you have the game showing on the screen. Make sure the game is turned on before you start changing inputs..
Oct 31, 2008 | iLO 3200 32 in. LCD Television
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Mitsubishi WD 52525 & PS 3
First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
Dec 25, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Onkyo TX-DS575 Receiver Logo
88 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
