Question about LG LRE30755ST Kitchen Range
I HAVE A LRE30755ST KITCHEN RANGE THAT TEMPERATURE CONTROL DOES NOT WORK THEY ALL TURN ON BUT WE AREN'T ABLE TO REGULATE THE TEMPERATURE.
  • 2 more comments
  • acabriones Feb 08, 2010
    I NEED THE PART NUMBER IN ORDER TO BUY IT AND I,M WILLING TO SHANGE IT MY SELF.
    BEST REGARDS;
    ACACIA.
  • acabriones Feb 09, 2010
    HI... I HAVE A LRE30755ST LG KITCHEN RANGE THAT WHEN WE TURN ON ANY OF THE BURNERS THEY START AT HIGH AS ALWAYS BUT FROM THERE ON WE ARE NOT ABLE TO LEVEL IT DOWN FROM THE HIGH TEMPERATURE.
    BEFORE I ORDER THE TERMOSTAT I JUST WANT TO BE SURE I EXPLAIN MY SELF CORRECTLY I'M FOREIGN AND MY ENGLISH IS NOT THAT GOOD. WE RECENTLY CHANGE ONE OF THE FIVE UPPER ELEMENTS THAT DIDN'T WANT TO WORK AND IT DID WORK PERFECT FOR A WHILE BUT KNOW FOUR OF THEM WHEN WE TURNED THEM ON THEY GO ON HIGH AS USSUAL BUT WE ARE NOT ABLE TO LEVEL THEM DOWN (FROM 1 TO 9) THEY JUST STAY IN HIGH, JUST ONE OF THEM WORK PERFECT AND THE OVEN DOES NOT WORK AT ALL AND SUDDENLY IT WORKS PERFECT FOR A MOMENT AND THEN IT DONT WORK ANY MORE. IS THE TERMOSTAT ALL THE PROBLEM???
    We have more then two years with kitchen range and yes it does start on high heat on every top element the problem is that now from the five elements only one is working propertly and the other four they start at high temperature and we are not able to lower them down plus the oven don't work at all and some times the oven just work perfect for a little time and then again it doesn't work at all.
    the elements they stay the same just one work perfect and the other four just run on high temperature.
  • 10,319 Answers
The gas regulator is in need of replacement. you can see it were all the burner lines conjoin together then that one large line connects to the regulator
Posted on Feb 09, 2010
    President:
  • 2,468 Answers
I believe if you look in your owner/user manual on page 7 this model starts out every time on high heat on every top element and you lower the heat setting on the stoves keypad control
  • 767 Answers
You are going to need a new thermostat for your oven. The thermostat regulates the oven temperature by turning on and off the elements. The thermostat is usually located in the upper, rear section of the oven and connects with two wires and is held in by two screws. Order a replacement and the oven should work normally after replacing the thermostat.
  • Heath Moyer Feb 09, 2010
    The part number is 1351398 and it is the thermostat.
    I sent the part number in another post for the thermostat through my email. Just in case I will give it to you again 1351398 .
  • 1,284 Answers
Hi, this is a simple case of worn out control which needs to be replaced and i will advice you to call in a technician for proper replacement and servicing so that you do not damage a wire or short it out while trying your self.
Take care
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Posted on Feb 08, 2010
  • Shehu Pro
    Shehu Pro Feb 09, 2010
    Hi, i don't know the part number for now and even if i do and i give to you, i am definitely sure that you cannot replace it yourself but if you insist, goodluck.
    It's only a technician that can get the part number for you after access the damage...
    Take care
Oven heats up to set temperature of 500 degrees, and shuts off completely on its own. replaced electronic control, and it still does the same thing. Any suggestions??
Does it have a thermostat to regulate the temps? If it is working correctly it will turn the element on and off to maintain the set temp.
There is also some thermo couple in there to regulate the flow of gas. If that goes haywire gas does not flow properly and ........
Nov 24, 2015 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Sometimes two of my rings will not go higher than low. What could be the problem?
The problem is most likey the switch for those rings. Usually there is no way to repair them, they have to be replaced.
Jan 26, 2011 | LG LRE30755ST Kitchen Range
My problem is the large burner on this stove tends to do somewhat ok on anything below a medium temperature. If you turn the burner to medium it escalates to high and refuses to lower even when you put the...
Replace the switch that controls this burner to get it back under control. This will solve your problem as the switch is what controls the burner temperature regulation.
Good luck!!
Jun 15, 2010 | GE JBS03 Electric Kitchen Range
Presumed bad circuit board on my LG LRE30755ST electric range
You may wish to try removing and re-seting some of the connectors on the back of the control panel...worked for me when our oven and timers stopped working.....
Remove the sheet metal panel at the top of the back of the oven..three phillips screws....then slide the two blue ribbon, wire connectors out, and re-seat them a few times to get a good connection.
Try to un-seat and re-seat some of the others aswell...perhaps un-plug from the wall first....but make sure there is good connections....then re-plug in, and see what happens...
Jan 02, 2010 | LG LRE30755 Electric Kitchen Range
LRE307555SW/SB/ST\03 Nothing works, nothing.
Donna:
Have you checked the main power input terminals first? they do carry a lot of current and are subject to burning off,then if electronically controlled,it could be an electronic fuse in the ovens control panel/keypad shutting things down,somewhat unlikely though...let me know and thank you for using this site.....Dan
Nov 04, 2009 | LG LRE30755ST Kitchen Range
The two large burners will not turn on, it started with just the inner burner on the dual size (the switch showed it on but it did not heat) now neither front burner switch will turn on
you are going to have to buy a new burner part. if you are able to open the stove top and look closely at the element inside you should notice that somewhere along the lines of teeth, it has broken.
Jun 28, 2009 | LG LRE30755ST Kitchen Range
LG LRE30755ST Kitchen Range Logo
117 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
