Question about Compaq tc1100 Tablet PC
Audio out-jack doesn't work
When I plug speaker or headphones in, nothing happens. The built-in speakers keep working, but no sound comes out from the speakers. Is this a hardware problem or something related to a setting?
  • Anonymous Mar 17, 2014
    The speaker doesn't work correctly. It is too loud. There are only two different sound levels available. Either mute, or the highest sound possible. It works perfectly with headphones, but the speakers are getting on my nerves
  • 24 Answers
There is a physical connection that shuts off the speakers when you insert the plug and push the connection open. It may be damaged or stuck. Probably need to open the unit to see. Did this connection used to work?
Don't force anything into the hole as this may already be the problem.
Posted on Apr 05, 2008
No sound except through headphones
The fact that the device produces audio output through the headphones indicates that the audio system is operable up to the headphone jack. Therefore, the fault must lie in the internal speaker, the wiring between the jack and the speaker, or the jack itself. Most likely, the internal speaker has gone belly-up and needs to be replaced...
Mar 26, 2016 | Tablets & eReaders
Speakers do not work. Headphones do. Tried adjusting volume but nothing changes
Possible causes are:
faulty conections on speaker cables, check all conections.
cable damaged, replace cable
speakers faulty, replace speakers
Feb 03, 2016 | Dragon Touch Touch7 Blue Dual Core Y88...
My headphine jack simply won't work. I have tried multiple headphones, but it doesn't sense them or something because it continues playing out of the speakers.
is it a tablet?....phone?....laptop??? you dont say. If it is a laptop..make sure you are plugging it into the 'headphone' jack...not the input or mike jack. they all look the same except for color. if itis a tablet...go into the settings and see that the headphone jack is set to 'headphones' and not 'speaker'
It is possible you have a defective headphone jack...there is a small switch build into the jack that disconnects the speakers and turns the headphone audio path to the headphones. sorry..now I see what the device is
"same answer"
Mar 18, 2015 | Nextbook Premium 8 Se Android
Orbo Jr. tablet. sound comes out of headphones but not without the headphones plugging in. I did a factory reset but no luck. Help
"No sound on external speaker" problem is often caused by:
- damaged speaker,
- damaged headphone jack,
- damaged audio codec (hardware).
You can try to ask your problem here: https://www.elvikom.pl
There are many service technicians with high-level experience, which may help you to repair your tablet.
Jan 19, 2015 | Tablets & eReaders
For Christmas I received an Archos tablet and my headphones jack stopped working. Instead of playing sound through headphones while they're plugged in, it plays through the built in speakers. Is there
Every thing is low quality chines junk these days and probably head phone jack input is broken and it is not repairable as all similar items ,
Jan 13, 2015 | Archos Tablets & eReaders
When I plug the headphones into my Samsung Galaxy 10.1 tablet, the sound comes from both the headphones and the speakers on the tablet, shouldn't the speakers be turned off by the headphones?
This can be a hardware (bad headphone jack) or a software (rom update) issue. If the tablet is in warranty, try taking it to your dealer and see if they have a fix.
Otherwise, some people have had success doing one of the following:
1. Plug headphones in after starting music. Watch for headphone icon to appear on screen, meaning tablet has recognized that headphones are attached. Make sure plug has been put into socket all the way.
2. Install app SoundAbout on your tablet and see if you can route sound to headphones only.
3. Check Settings/About Device to see if there is a software update for your tablet. Install the update and see if that fixes the problem
Jan 12, 2015 | Samsung Galaxy Tab 101 Tablet...
Ipad 3 sound garbled
Is there difference between speaker and headphone jacks ports
Not all computer headphone jacks will work with speakers. So, it would appear that your computer is one them. Read the article I've linked.
Jun 05, 2014 | Apple iPad 32 GB WiFi Tablet PC
No sound from built in speakers.
The bleep cold be just a bleep device separate from the speakers. It looks like a round piece of aluminum with a large dot of white solid past on it with a wire attached.
1st. make sure the volume is up all the way.
Then try using a headphone just to make sure the sound card is working.
If the headphones work then it should be a setting somewhere.
Sometime the switch that turns off the speakers when headphones are plugged in gets stuck, try plunging them in and unplugging them out while music is playing.
If they don't work the sound card may be blown but it is still possible it is not.
Also, try Keyboard shortcuts for mute and UN-mute.
Try going to control panel and bring up the sound app and try different options in there for mono and or what ever it has, you may find the answer there.
If the headphones work but nothing else works you can always plug external speakers in the headphone plug.
Sep 28, 2017 | Toshiba Tecra M4-S435 Tablet PC
My lenovo y 430 has no sound for hedset & subwoofer doesn`t work. ... and right speaker works but left one doesn`t what should i do?
Make sure that the correct playback device is set as default in sound properties.
If all is well there then you could try a pair of headphones to see if the sound is working.
If headphones work ok then it is down to your built in speakers, not much you can do unfortunatly unless you are still under warentee
Jul 10, 2010 | Lenovo Tablets & eReaders
Fujitsu T series; no sound when I plug in the headphones
I have the same problem and just figured it out. Go to the sound settings and set the earphones as the default. I just did this and it now works.
Nov 27, 2008 | Fujitsu LIFEBOOK T4010 Tablet PC
Compaq tc1100 Tablet PC Logo
318 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
