Question about HP Photosmart 3210 Printer
My printer won't turn on, won't start, no response
My printer, a hp 3210 won't turn on, won't start, no response at all.
It used to work just fine. I was ill for a couple of months
and didn't use it . Now it's deader than a door nail.
  • fjbriscoe76 Feb 08, 2010
    I've tried that several times with no help. Do you know of any history of this problem?
    Any weak component that could cause it? Do you have any disassembly suggestions?
  • 233 Answers
Please check power cable, replace it. try other power source.
Posted on Feb 09, 2010
  • Deny Mulia
    Deny Mulia Feb 09, 2010
    yes sure I have any suggestion, usually its happen because the capacitor on power supply board is bloke ( bloated )
    1. Just open your printer
    2. make sure the Fuse is still working
    3. look for Power Supply board
    4. there is any bloated Capacitor ?
    5. replace the capacitor
    Normal and bad capacitor Picture :
    With Yellow circle is Good Cap, the red circle is bad cap.
  • 10,865 Answers
Hello. Unplug your printer from the wall and test that outlet to be sure you have power there. Also check the other end of the printer cord to make sure it is completely inserted. regards, Joe
Posted on Feb 08, 2010
How can i use hp 3210 all-in-one printer with toshiba chromebook
The 3210 can be connected either through a USB port directly to a computer or ethernet cabled to a router or switch. Either will work. Personally, I would connect it using ethernet (~$15 for a cable) because then it becomes a common resource on your home network.
Jun 14, 2014 | HP Photosmart 3210 Printer
My HP photosmart 3210 skips lines on the black ink only. The other colors print fine.
(The obvious) Replace the black cartridge. Even if ot says you have ink you could have a faulty cartridge, even if it has worked fine in the past. (The not so obvious) Clean your printheads/nozzles. Repeat the process a few times.
Apr 27, 2011 | HP Photosmart 3210 Printer
Photosmart 3210 bought Dubai need to change region Spain
Hello Friend
You can change region settings of your hp 3210 printer by changing your language preferences.Just select the language of your region and it will be fine.
Thanks,
Viju
Apr 03, 2010 | HP Office Equipment & Supplies
Photosmart 3210 - A Printer alignment failed error
Mine has done the same thing.
To fix this you have to reinstall the software, then reboot your computer.
I did that, and the printer alignment function worked fine for a while, then I started getting the same problem again, possibly after I had installed other software not related to the printer -- I don't really know.
In any event, it's doing the same thing again, so I just "cancel" the alignment and continue to use the printer. My prints are fine.
Jul 20, 2009 | HP Photosmart 3210 Printer
Re-configuring for european ink cartridges
i had thed same problem. after hours of trying different options i finally got it to work. i have a hp 3210 that i brought from the usa to irelnad and when i put in irish cartrtidges it said " this printer is cinfigured to use 02 cartridges" Iriss cartridges are 363. so what i done was , while the printer was turned on i held down the " Black" button and the "Color" button at the same time. Keeping them held I powered off the printer , keeping them held until the printer was completely powered off. when i turned the printer back on the region had being reset and it asked me to choose my language and country. chose " Ireland". Now works!!!
Apr 25, 2009 | HP Photosmart 3210 Printer
HP psc 1215 does not print
I did it on my own. I just uninstalled the printer and reinstalled using the installation cd. Although the cd was old (from when I bought the printer and now I have vista) it works now. Good luck all.
Jan 10, 2009 | HP Photosmart 3210 Printer
Sudden printer rebellion
ok.....try this site for fresh drivers..and check the power cable into the supply for that printer..should have a small light showing it's working.
Dec 01, 2007 | HP Photosmart 3210 Printer
Photosmart Essential Lockup
Hey guy don't follow thier suggestion. No one can't do anything for u r problem because Your H.P. inkjet Printer 3210 doesn't work with Vista. I am also faced same problem. It is technical problem. Just change your vista or Printer
Jul 02, 2007 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
