Question about Fisher and Paykel Dishwashers
Hi
Thanks
for using FixYa. If you have water leaks around the base of your dishwasher,
you may be using a detergent that is causing too much suds. Cut back on the
amount of detergent you use, and see if that makes a difference. Water that
spills through the door vent is usually caused by improperly loading dishes.
Leaks from the door itself may be caused by a faulty door gasket or door
tightness adjustment. You should check the main tub seal, the door latch, the
door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet
up or down, and many units have some type of levelers at the rear). Water under
the dishwasher may be originating from a leaky hose or loose hose connection.
Remove the lower front panel, and check the hoses. The pump seal may be
defective, too; replacing this is a job for an appliance repairperson. An older
dishwasher may corrode at the bottom, but this is fairly uncommon. If this is
the case with your dishwasher, it's time for a new one.
Please do
accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
Posted on Feb 08, 2010
on Sep 10, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Mar 22, 2014 | Fisher and Paykel Dishwashers
Sep 12, 2011 | Fisher and Paykel OR24SDMBGX1 Gas Kitchen...
Dec 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Mar 25, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Mar 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Feb 09, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dec 29, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Feb 25, 2018 | Fisher and Paykel Dishwashers
