Question about Bernina Artista 180
Have 4.0 software. When trying to load pattern to 180 Bernina I get the message no link to serial port.
  • 28 Answers
Which version of Windows do you use? There is an additional software to download from the Bernina website for Windows XP which solves that problem.
Posted on Apr 11, 2010
I purchased a serial port that is not compatable with my sewing machine, I also purchased an updated software with Bernina to make my embroidery machine user friendly. however,I am unable to connect
Problem is that the Bernina software you are using expects to talk to a 'COM port and the PC's USB serial interface doesn't automatically default to a COM port. Make sure you have installed the software that was delivered with your USB-to-Serial adapter and look on your PC's 'Device Manager' under 'Ports' - you should see the USB adapter listed and it should be assigned to a COM Port number. You need to check what COM port numbers are accepted by the Bernina embroidery software (sorry, I cant remember and haven't got one here presently) - it should be in the Options menu. You have to ensure that the USB 'virtual COM port' is the same as that which is set in the Bernina software. If the Bernina software doesn't support the COM port allocated to the USB interface, go to 'Properties, Port settings, Advanced, COM port number and set this to the same as the COM port number in the Bernina software - hopefully this should set up the link OK, provided you haven't got a COM port clash - to avoid this, it's usually best to choose a COM port number of 2 or above.
Dec 02, 2011 | Bernina Artista 180
I want to connect my laptop to my Arista 170 using an usb to serial port cord. where can I find the correct cord?
I tried a Dynex USB to Serial cord found at Best Buy. worked great for an Artista 180. I used the Artlink software free download from Bernina. Works very well.
Feb 23, 2011 | Bernina Artista 170
How do I connect my 165 to a computer with USB ports only?
Use the free Artlink software from Bernina. The cconnector... use a USB to Serial port converter cable. Best Buy has them *Dynex brand). Worked for me on an Artista 180.
Feb 22, 2011 | Bernina Artista 180
How to repair a bernina hasp lock
HASP or security device dongles were used on earlier Artista software. If your machine still has a parallel port and the HASP devie is on the connector then you probably upgraded windows over time. There is a XP device driver fix you may need to install. I recently loaded the ancient Artista software into a modern machine so I know it can be done. Just need to have the proper hardware support.
If all your trying to do is communicate with the machine from the PC then look into an USB to SERIAL converter and use the Artlink software from Bernina (free). Has much of the function that the earlier software did except for limited edit capabilities.
Jan 02, 2011 | Bernina Artista 180
Usb/serial adapter not working
check the com port of the appliaction, it is based on com1 only then you will need to make changes to the com4 to com1 follow these steps
open device manager
choose com4 and then right click for properties
choose port settings
choose advance
change the port number from 4 to 1
that will be all you can now give it a shot again
Jan 01, 2010 | Bernina Artista 180
Bernina 180 usb to serial cable not working
it's in your computer control panel - you need to assign the com port to the cable - it took me a few tries.
In the long run, I bought the Editor Lite software for $120 on ebay - it comes with a USB dongle - that solved all my issues other than assigning the com port to the serial port. It all works like a charm now.
Oct 10, 2009 | Bernina Artista 180
I need to convert my parellel port dongle to USB
I have the same problem...V3 software. have not heard of an adapter. The software wouldn't work with Windows XP or Vista anyway. I upgraded to Editor plus V5 but have kept my old Designer plus on an ancient laptop so I can transfer old patterns. You will also find that your new laptop doesn't have a serial port to accomodate the old cable to bernina 180. Unfortunately it's always the case with updating a PC. Everything else has to follow! My advice, get hold of an old laptop:)
Jun 16, 2009 | Bernina Artista 180
New computer won't work with Artista software
You need a new security code. When we changed computers we worked with the dealer on where to send the form requesting Access code. You can find the form under Help on the far right of your menu bar. It's the last item called Access Code Order Form. They emaild it back to us with the code we needed along with the install instructions. The dealer should also be able to assist you with your laptop issue, although you may only be able to use the software on 1 PC or laptop as you are probably licensed for 1 copy, and they us the dongle to validate the software and the machine combination.
Best of luck.
Nov 20, 2008 | Bernina Artista 180
Connection problem with computer to sewing machine and reader/writer
It is not true that the 180 is not compatible with new software.
I'm owning a artista 180 from 2002 and just installed the software designer V5+ on a laptop with windows vista.
The only problem was that there was no serial port on the laptop, now I have a new cable with USB ans serial output and the software works very well !!
When you contact Bernina you will get the same answer.
greetings Carla
Jul 16, 2008 | Bernina Artista 180
Sewing Machines Logo
112 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
