Question about Canon Pixma iP6600D InkJet Photo Printer
Canon iP6310D photo printer
I have spoken w/ canon & Dell and, although I finally got the printer drive recognized by the computer when I go to print it says the printer is not responding. The printer DOES work from a camera card and from my daughter toshiba laptop. Thus I am still left wondering if there is a Lexmark file interfering with the inf. files from the canon. The canon tech guy said this might be a problem but Dell didn't seem to respond to this idea. Any suggestions on how to make sure the Lexmark stuff is GONE and only the canon files are present and active?
Thanks,
Nan
I had Power Spec window ME. and not too long ago I boght Canon printer IP6310D and it work very well though I didn't have CD ( just connected) Later on my computer had weirdly acted. I assume that it may not enough memory or hardrive failed. So, I took them out and in this system it has only two chips memories total 356 GB and 20 GB hard drive. Then I bought 160 GB hard rive plus 512 GB (in one chip) memory. Ok I put a new hard drive and 768 GB memory in( I couldn't put them all cause only two memory slots) Final tested, The word popped up " If you use USB 2.0 it will be faster" some thing like that. I went to where I bought the computer from and the told me to go to Power Spec website and I did that but didn't find anything concernig this problem. They told me that I need to change new windows Exp or vista and I did change to window Exp. Wow! every is great surfing online faster! Alas, The printer still not work.I tried it again and again at this point not a word, nothing happen when I clicked on print Icon. Please advice me, what I suppose to do. May thanks in advance!
Paul
Posted on Sep 26, 2008
  • phans256 Sep 29, 2008
    I did as I was told. But the system won't let me Remove my old drivers. So, I just re-added up the same printer and it didn't work.
    Paul
    Habit-Forming:
  • 59 Answers
You can do the following to check and remove your old drivers.
Assuming your using Windows, click on START, then Printers and Faxes.
In the new window click on File and then Server Properties.
From here select the Drivers tab and see what drivers are listed there and select any Lexmark ones and push the Remove button. Reboot.
You may want to disconnect your Canon printer and remove it's drivers also and then reinstall them fresh again and see how you go.
You could also try something like Driver Genuis - http://www.driver-soft.com/ which is supposed to be able to remove old and unused drivers, but it's a paid product and i'm not sure how effective it is.
I would tend to agree with the Dell staff that it should matter if you have old drivers still on the system as it will only use the drivers/files that are required by your hardware.
I would also try the different USB ports on your Dell machine and possibly a different USB cable just in case.
Posted on Feb 22, 2008
Need to find out how to open printer to replace ink cartridge
press the start button located at the lower right side of your computer monitor.then click the control panel button then click the "printers and faxes" button then click the "Canon PIXMA iP6310 InkJet Photo Printer" button then click the button "replace cartridge" and it will automatically set for you to open the cartridge holder then carefully detached the cartridge from the holder..
Mar 06, 2011 | Canon PIXMA iP6310D InkJet Photo Printer
Ink absorber full
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge
Aug 19, 2009 | Canon PIXMA iP6310D InkJet Photo Printer
I hook up camera and photo printer press print and camera screen say no print head I just put new cartrigdes it worked fine yesterday , its like the printer is froze, I can't even run a head alignment
You need a new printhead, they can be just like a light bulb sometimes, in that they work fine one time and the next time you go to use it it's burned out.
Aug 02, 2009 | Canon PIXMA iP6310D InkJet Photo Printer
Canon iP6310D does not print text in black
1 reason for this may be that there is no ink in the cartridge
2)the inkhole is blocked
You may need to do a clean and nozzle check till the ink runs and it prints the check pattern using black. or replace the cartridge
Jul 30, 2009 | Canon PIXMA iP6310D InkJet Photo Printer
Can i use pg-40 cartridge in my printer
No, you can't. I have the same printer and tried to save a buck at Costco, where they sell a 41 and two 40's in bulk. However, the 40 wouldn't fit into the slot because the ridges are slightly different. Several online print websites list the 40 as being compatible, but it would fit on my iP6310D.
Take the 40 back and go somewhere that sells both the 41 and the 40.
Anyone who wants to buy 1 opened (but unused) and 1 unopened 40-ink cartridge, please email mjc_co@yahoo.com and I can either sell directly to you or put them on ebay. Thanks!
Apr 30, 2009 | Canon PIXMA iP6310D InkJet Photo Printer
Blank pages
download the driver that is compatible with mac for your make of printer
Mar 02, 2018 | Canon PIXMA MP210 Photo All-In-One Printer
Canon printer Pixmaip6310D
If your using regular cartridges and not the FINE ones, make sure put full cartridges in or indicator will read incorrectly. If you haven't gotten any error messages and said proceed anyway ( you'd know because it would've told you that this would disable your ink monitor), just put in the full cartridges and do a print head alignment and this should solve your problem.
Mar 17, 2008 | Canon PIXMA iP6310D InkJet Photo Printer
CD ROM Doesn't work, need driver for pixma iP6310D
hi i am a certified Canon4.gif repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Dec 14, 2007 | Canon PIXMA iP6310D InkJet Photo Printer
Printer issues
If you are using Glossy paper, when you go to print make sure to go into the printer Properties from the Print dialog box and select Glossy paper in the type. This will put the printer into it's highest print quality mode.
So from most windows applications, it would be :-
CTRL-P (to print with dialog box for changes)
Click on Properties
Select a Media type of glossy photo paper
Select standard or high print quality.
p.s. you may need to experiment which if the media types gives you best quality for the paper your using, unless it's Canon paper and then just match it up.
Oct 29, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
old marine
old marine
