The problem would be on the screen and it says NVIDIA Boot Agent 244.0538 Copyright (C) 2001-2005 NVIDIA Corporation Copyright (C) 1997-2000 Intel Corporation PXE-E61: Media test failure, check cable PXe-M0F: Exiting NVIDIA Boot Agent
  • blazing456 Feb 09, 2010
    it is a lap top, the make is hp pavilion Entertainment PC, and the model would RG408UA
  • 4,806 Answers
It sounds like the boot order has changed within the BIOS configuration or, the hard drive has failed. PXE means it's trying to boot from network (LAN/Ethernet)
First of all can you please tell me if the machine you have is a desktop or a laptop computer, and what make and model.
This is because you have to hit certain keys to get into the BIOS with certain makes of computer.
I look forward to your reply.
Posted on Feb 08, 2010
  • Lee Hodgson
    Lee Hodgson Feb 09, 2010
    Hi.
    We need to change the boot order or determine if the hard drive has failed.
    1. Turn off the computer and wait five seconds.
    2. Turn on the computer.
    3. When the first screen displays, immediately press the F10
      key if your computer was built in 2006 or later (came with Vista). Press the F1
      key if your computer was built before 2006 (XP or earlier). Press the
      key once every second until a BIOS Setup utility screen opens
    Use either the F1 key or F10 key until you get into the BIOS. When in the BIOS you can see in the Main/general page whether the hard drive is seen by the system. You will see HDD (hard drive) CD-ROM which is the optical disk drive.
    If you see the hard drive the look for boot options in the tabs. When you get to boot options set the HDD as the first boot device, save the settings and exit the BIOS.
    Hopefully the laptop will restart and boot from the hard drive, thus into Windows.
    I hope this information helps to resolve your problem but if not or you need anymore advice please post back.
    Good luck.
How do i fix it?
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 02, 2012 | E-Machines eMachines Desktop PC
I have a dell XPS 1340. it has core 2 duo processor. i'm using windows 7. i was using it and then suddenly it just hung up. i restarted it and then it gives me some kind of I O error and says it was...
PXE is for network booting. It sounds like your hard drive died and the BIOS is looking to boot from another source. It could also be a power supply problem... but not as likely.
Your best bet is to remove the drive from your laptop and connect it to another PC via an external USB drive case (cheap at newegg, frys, etc) and try to get the data off of it that way. If the drive does not spin up at all, you can get the data back by sending the drive out to a place like Ontrack, but it's not cheap. If it does spin up, and isn't making odd ticks or noises, then the problem lies within the laptop and you'll want to get in touch with Dell.
If you send it to Dell for repair, do not send the hard drive without backing it up first. Odds are, you won't get the same one back.
Jun 27, 2011 | Dell XPS 1340 Notebook
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
Hi, i put together my own computer, ive got the following components: i7 870 processor CPU 8GB RAM 2TB hard drive (two separate 1TB's) NVIDIA GTX 470 DP55KG extreme motherboard coolmaster 850w...
It is telling you that the motherboard can't find the first item on the boot order where it is looking for an operating system, or a bootable disk CDR-DVR. This is usually the DVR Optical Device, or it may be the hard drive. Check your connections on DVR and Hard Drive both at the device and and at the motherboard. Pins in the hard drive and DVR are fine and easy to bend.
Mar 29, 2017 | Computers & Internet
I turned laptop on and get this message over and NVIDIA Boot Agent 249.0542 Copyright (C) 2001-2005 NVIDIA Corporation Copyright (C) 1997-2000 Intel Corporation PXE-E61: media test failure, check...
your harddrive is either failed or your harddrive master boot record is corrupt and you will have to reinstall windows or the linux you used
Dec 14, 2010 | Computers & Internet
Hi When I start up my Acer Aspire L100 mini desktop, it makea clicking noise, which emits from with the computer and then the computer freezes with the screen below. Also, sometime I have to power off on,...
You can solve this problem by:
-- cleaning system junk
-- optimizing computer services
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Also remember to uninstall and reinstall updated drivers for your devices. Thanks
Nov 10, 2010 | Acer Aspire L100 PC Desktop
Computer freezes and shows a fault screen
Remove all the physical components of your computer and have it clean. You can use a brush or a blower and then reinstall your computer operating system. If it is windows xp then you will be needing the software for windows xp installation and then support cd for your motherboard and all support drivers.
Nov 15, 2009 | Acer Aspire L100 PC Desktop
I have a acer aspire 5520 and it comes up with NVIDIA Boot agent 249.0542 copyright (c)2001-2005 NVIDIA corporation copyright (c)1997-2000 intel corporation PXE-E61: media test failure, check...
i think your harddrive got a problem.Maybe the hd are defect.Go to the bios(press `del `when start up)Than look if you can see the hard drive.
Dec 01, 2008 | Acer Computers & Internet
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
