Question about Texas Instruments TI-84 Plus Calculator
How do you put degrees mins & secs in a ti 84 plus
  • Texas Instru... Master
  • 7,993 Answers
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Posted on Feb 09, 2010
  • k24674 Feb 10, 2010
    This key sequence
    should read
    1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+] [ENTER]
Unfreeze ti 84 plus calculator
hi
try pressing the clear key if that don't work than reset the calculator by pressing the reset button or remove the the batteries from it for one minute than put it in amd press the clear button and you should go to go however you may to check and change certain setting lile the degree setting i.e. radians to degree and fix to floating notation and other important setting as well.
I hope this helps.
Aug 27, 2014 | Texas Instruments TI-84 Plus Silver...
How to graph 5th degree polynomial TI 84
The TI-84 does not have a built-in quintic fit.
The most common scheme for fitting a model to data is the least squares. You'll find several programs to calculate this here.
May 24, 2012 | Texas Instruments TI-84 Plus Calculator
I have a TI-84 calculator. I can't figure out the exact buttons to press to find the sec of -1.2. It is supposed to be an answer in degrees.
First, check if the calculator is in degrees. Do this by pressing mode and selecting degrees (it should be about the third option down)
The TI-84 doesn't have a dedicated button for secant so you will just have to enter it as 1/cos(-1.2) or cos(-1.2)^-1
Mar 08, 2011 | Texas Instruments TI-84 Plus Calculator
Ti 84 mode a+bi you can not add 5 at 90 degrees to 5 at -90 degrees. You need to switch to exponential mode e^ and enter as 5 e^(pi/2i) this is ok for 180 degrees. however what do you do when...
You can add angle measures by hitting 2nd angle and choosing the degree option. Put this after a value (e.g. 90(degrees symbol)) and add you can add angles that way. Be sure that you are in degree mode when doing this (you can use the radian symbol for adding radians too). Still, this is a very tedious process and I recommend just adding angles as regular values (e.g. 90 + 200 = 290) and correcting for degrees manually.
Feb 21, 2011 | Texas Instruments TI-84 Plus Calculator
Ti 84 Silver Plus won't turn on
ti-plus doesn't turn on at all put new batteries in nothing and it is only a year old when I bought it
Sep 10, 2009 | Texas Instruments TI-84 Plus Silver...
I can't graph on my ti-84 plus silv. edition
More than likely, you've put in a number in the xmin or xmax that is not correct. Example....you put in an xmin of 10 and an xmax of -10 which would be backwards. This could also happen in the ymin or y max.
The easiest way to fix this is to press zoom 6 which wil get you back to the default graph of xmin of -10, xmax of 10 and ymin of -10 and y max of 10.
If you can't see your graph on this screen and need to change the window, just be sure the number in the min for both x & y is smaller than the number in the max. You change your window size by pressing the window button.
Aug 13, 2009 | Texas Instruments TI-83 Plus Silver...
Minutes and seconds and degrees button
Here:
http://education.ti.com/guidebooks/graphing/84p/TI84PlusGuidebook_Part2_EN.pdf
Look at page 89 about DMS.
Rate me, thanks.
Jun 20, 2009 | Texas Instruments TI-84 Plus Calculator
Degrees, minutes and seconds button
Press the blue "2ND" button in the top left hand corner, then locate the "ANGLE" button, or "APPS" button and press.
It should give you a list of symbols.
The first two are: Degrees and Minutes.
As for seconds, press the green "ALPHA" button, then locate the "+" and press.
May 19, 2009 | Texas Instruments TI-84 Plus Calculator
I have a TI-84 Plus. need help finding sine of an angle
make sure that your mode is in degree, not radian. YOu can change it by simply press mode and move down to the degree selection and press enter.
Mar 06, 2009 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
1,803 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
