Using EasyCapDC60 with Ulead Video Studio 10.0. After a lot of probs(partly solved by using mic jack etc) can record old VHS tapes. But the sound is poor - a lot of reverb. Any answers? Thanks
    Scholar:
  • 32 Answers
You can play your VHS tapes on your VHS machine and use a better microphone that is placed at the optimum distance to eliminate feedback. This is not the way to go though because you are doing a valuable task with inferior way of getting a good result. Best way would be to get a VCR to PC Conversion System at an electronics store. I priced one at Radio Shack for $99. You probalby can do better at Fryes Electronics or look on the Internet (Google or Craigslist search amy turn up a better price or a used one).
If you and play your VHS through your current TV or Stereo system you may be able to use the audio out to your PC or other recording device.
The reason that the conversion system is so much better is that they are changing from the analog to the digital system and this is a direct way to rerecord the orignal recording without microphone feedback and room distortion noises.
Hope this helps you resolve your issue.
cmilton111
cmilton111@gmail.com
Posted on Mar 01, 2010
Video capture ezcap ver36.1s
I had the same problem. I attempted to solve it by using two EZYcaps with the idea of splitting the sound and video streams but as they use the same driver that didn't work. Splitting the video and sound inputs to two USB ports is the key to success. What did work was when I tried plugging in an old USB SoundBlaster sound stick. It is a little thing like a thumb drive but with two mini jacks, one for mic and one for earphones. I plug the mic into the SoundBlaster and the S-Video into the EzyCap. As the SoundBlaster uses a different driver they don't clash.
I also use "SplitCam" to put it all back together and stream the whole lot to the internet. Split Cam also lets me stream to inSpeak video chat while I also stream to Livestream. check out the results on www bgemc.org site. The second EzyCap sits as a spare in my bag. I also audio record the service at the same time. This is all done through a Toshiba Satellite laptop. CPU usage is usually below 30% often down to 10%. By the way I used to use ManyCAM and U-Stream but didn't get good results. All the best. Malachi.
Mar 28, 2014 | bessac.ca Ezcap USB 2.0 Video TV DVD VHS...
I purchased the easycap usb 2.0 program a week ago and have not been able to get a signal from my vcr to pc. i have tried the ulead video 10 software, windows movie maker and golden video and all i see in...
anyone using the front usb ports on your pc, don't! use the rear usb's in the back of the pc and presto, works great! best thirteen dollars i ever spent! and also don't use the ulead software, my there was a delay in the video for the voices, windows movie maker is the way to go for capture!!
Mar 05, 2010 | Ulead VideoStudio 9
No audio when importing vhs tapes into moviemaker via composite
you need to connect rca jacks or the mini jacks to the anolog side of your sound card and the 9 pin connector will use for video to capture aslo if your using windows movie maker you need to select the imput type and mpeg 2 or mpeg3.
Jun 19, 2009 | Pinnacle Dazzle DVD Recorder
U lead video capture
It's either something to do with your PC sound settings. Maybe the recording level for sound is set to low or switched off. Or it's in the Easycap software where the audio is switched off.
Jun 11, 2017 | Ulead DVD Workshop 2 for PC
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
Audio in EasyCap/VS10
I had exactly the same problem and solved it by updating the drivers for the USB sound/audio device.
My XP version is in Swedish so I´m not sure what it says in English, but it should say something like the following.
Go to the "Device manager" by right clicking on "This computer" and choosing "Properties", locate the "USB sound/audio device" under the "Sound, Video and Game"-category and right click and chose "Update drivers". Then chose "Search for drivers on the internet" and chose "Recommended installation".
My new drivers are called "USB EMP Audio Device". They work perfectly.
I wasn´t able to update the actual EasyCap video adapter, but it doesn´t seem to matter if you´re having problems with the sound. Although I can´t use an S-videocable, only a videocable, otherwise the picture turns black and white.
Hope this helps!
Mar 07, 2008 | Ulead Videostudio 8 for PC
Ulead vedio studio 10
Ulead video studio - is not a free software ! U'll only find demo downloads ...
If u really want it u'll be able to download it through sharing software (strongdc, torrents, etc ...). Though if u afford it ! Buy it !
Jan 30, 2008 | Adobe Photoshop 7.0 for PC
Playback *stops* on tapes where I used Aux input to record
It could be that.. you generally want a timebase corrector to properly record from analog tape to some other medium. But maybe not. Most tape-based devices also include a tension sensor, to detect the end-of-tape. If you're using tapes that are too old, cheap, etc. it could be that you're seeing this triggered.
I recommend trying the same VHS recording with a good quality, fresh tape. If it's still kicking off, you at least know it's due to the camcorder having issues with sync or something on the tape. If it works, blame the old tapes.
It's probably camcorder dependent, but I have done tape restorations using Digital8 and DV equipment, and have never known a camcorder to cut itself off due to dropouts or other problems on the tape -- mine just play through. So I think it's at least possible that it's just the tape.
Jan 20, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
Sound
if it has a external mic jack you could see if that is working. if it is then the mic on the camcorder is bad.
Sep 15, 2007 | Panasonic VHS-C PV-L354 Camcorder
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
