Question about Citizen Eco-Drive BL006056H Wrist Watch
HOW DO I SET THE DATE , THEY SAY IN THE MANUEL SOMETHING ABOUT LEAP YEAR.. I WOULD LIKE TO SET IT ONCE AND FORGET IT
  • 2,334 Answers
Find my tips here on FixYa and follow the link for CITIZEN watch manual. Click on Eco Drive watch and use INTERACTIVE settings. Everything is explained and shown there. Rate me, plz.
Posted on Feb 09, 2010
Has no leap yr. went from 2/28 to 3/1 cannot coordinate time
  • Auto Calendar (pre-programmed until the year 2039)
that means, you need to set up correct year in order to show leap years.... and then it will show you also correct day, after you will set it up correctly..... http://support.casio.com/storage/en/manual/pdf/EN/009/qw1545.pdf
check page 2
Mar 02, 2016 | Casio DW-5600E-1VCT Wrist Watch
How frequently do non-leap Februaries with only 4 weeks occur ?
We add a Leap Day on February 29, almost every four years. The leap day is an extra, or intercalary, day and we add it to the shortest month of the year, February.
In the Gregorian calendar three criteria must be taken into account to identify leap years:
  • The year can be evenly divided by 4;
  • If the year can be evenly divided by 100, it is NOT a leap year, unless;
  • The year is also evenly divisible by 400. Then it is a leap year.
This means that in the Gregorian calendar, the years 2000 and 2400 are leap years, while 1800, 1900, 2100, 2200, 2300 and 2500 are NOT leap years.
Jan 02, 2018 | The Watches
Is there any way that I can set my Seiko perpetual calendar watch at home?
What a great watch! It has a super-fine piezo-electronic motor to move the date wheel! Very cool. Its quite a show to go through the date/leap-year check, and then observe the watch catch back up to the correct time afterwards. Battery lasts ~five years.
I downloaded the manual (your model number on watch back) after a short search online (beware of trojans/viruses).
Setting after a battery replacement requires shorting certain pins inside the watch to set the leap-year, and date. The back unscrews, and may require the special watch-wrench, available online. I unscrewed mine VERY CAREFULLY with fine pliers, confirming that I was doing this in a clean, dust-free location. The instructions are quite specific, must be followed carefully to set up correctly. Have a fine wire jumper to set the leap-year. I learned this because I did not want to pay an inexperienced jeweler $100 to replace the battery.
Oct 13, 2014 | Seiko Watches
I replaced the battery. The watch started time from Jan. 1
You have to set the year, the month and the date. Then you set the time zone. After that you can set the local time. You may also have to set the Daylight Savings Time.
The watch has a built in calendar that may run from let's say January first 2000 to the year 2070 (just a guess). If you set the calendar correctly you do not have to adjust the date when a month has 30 days, or when it is a leap year.
Sep 27, 2013 | Casio GW330A G Shock Solar Atomic Watch
How do you know witch setting to make on the leap year adjustment on the Citizen Calibre 8700 model. +1, +2, +3...?
On Leap Years, the function dial is to be set to '0'.
Add one for each year after...
So, for 2011, set the function dial to '3' since it has been 3 years since 2008, the last leap year. Next year it should move/be set to '0' again since 2012 is a leap year.
Dec 23, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Need an expert on the new minute repeater by campanola, sold one at the retail jewelry store i work at, gentleman wants step-by-step hands on instruction as to the minute repeater function as well as the...
in order to set the repeater chime you need to set the watch and the sub watch to the same time.
This watch has comes with crown in position 0 , if you pull it out one level it becomes position 1 and if you pull it out one more time it is position 2 .
There are 3 buttons on the watch also. The button directly above the crown is button A the button below the crown is button B and the button directly across the crown is button C.
To set time you must first pull out crown to position 2 when the small second hand is at 12 o'clock position and it is stopped.
The mode will also at this time go to 0 and the sub watch second hand( the long second hand with the sun on it ) will also go to 0.
At this time you can just move the crown to set the proper time to the main watch . Now if you press the B button to set the sub watch . Each time you press the B button it will advance one minute hold down the B button and will advance time faster.
Do this to set the sub watch time make sure you watch the am and pm to make sure you are getting the proper time of day.
if the sub watch second hand ( the long second hand) is not aligned to 12 oclock then press the A button keep pressing button or hold it down to go faster until it is aligned at the 12 oclock position
Now push crown in back to 0 position for your time for your watch and sub watch should be set.
Set leap year.
Pull crown to position 1
Press the B button to adjust leap year.
the leap year is set by how many years from the previous leap year it has been . So 2008 was the previous leap year so we will h ave to set leap year at year 2 . The hands of the leap year are connected to the month so you must hold down a and b button or just press the b button to get to year 2 .
once you do that your leap year should be set.
to set the Repeater ( this is a beep from the watch to tell you the time with sound) make sure crown is in 0 position and hold a button for a couple of seconds to activate Reapter.
you can press any other button to end the chime .
also to get to leap year view while crown is in 0 position hold down the b button for 2 seconds . Pushes any button to return to normal calendar.
Oct 16, 2010 | Citizen Campanola Perpetual Calendar...
How to change the date and week?
1. Pull the crown out one click.
A. Turn dial until function hand rests on "CAL"
2. Pull dial out one more click (should be all the way out)
A. hold down button "A" (top button) until the second hand completes one counter clockwise rotation (should be pointing at current month)
B. Press "A" button a second time and the Day/Leap year hand will move.
3. At this point spin the crown either backwards or forwards and watch as the Day/Leap year hand spins clockwise or counter-clockwise. The Date will adjust per each revolution.
Hope this helps as it took me using the correct movement number on the url in the previous post (for Calibre 8700 the movement number is "E870").
Mar 22, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
To adjust time on a watch
If your watch has a crown that pulls out to set it pull crown out half a click. Then turn crown to set watch to proper dte.
Mar 01, 2008 | Watches
Setting the perpetual callender 8700
The year is now 2008 a leap year. You should set the watch to leap year.
Nov 02, 2007 | Citizen 8700 BL8000-54L Wrist Watch
Citizen Eco-Drive BL006056H Wrist Watch Logo
379 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
