Question about Samsung SGH-A707 Cellular Phone
External antenna We live in a rural area with no service so we have to use an external antenna to get service at home. We get 2 bars using the external antenna. We bought this phone new and since we hooked it up to the external antenna, it will not use it's internal antenna when unhooked from the external antenna now. It will only work now on the external antenna. We have gone back to using our old Sony Z500's, because they work fine. Anyone know anything about this problem?
  • Anonymous Sep 05, 2008
    same situation on two a707s. Factory reply to problem confirms worse fears - inserting the external antenna into the test port - what we were told was an external antenna port renders the circuit to the internal antenna open -
sawick420
SOURCE: Help with antenna replacement
When replacing an old broken antenna with a new one, say purchased off of Ebay, simply rip out the extendable part with a pair of pliers then rip out the plastc body that is attacked to the body of the cell phone(needle nose pliers work good because you can get one of the points on the inside whole of the antenna casing). I initially took off all the back screws underneith the battery and the one under the QuallCom link cover on the back and cut away at some plastic with an Exacto knife. This may not be a necessary step. Then you simply slide the new antenna in the phone making sure that the plastic tube is in place in side the phone. thanks for reading, hope this helps. Remember, easy does it till you get frustrated:)
Posted on Jan 11, 2007
SOURCE: error message on z500 phone
i have the same broblem but my cellphone is sgh- z140
Posted on Feb 19, 2008
SOURCE: Unlock a T-Mobile BlackBerry Pearl 8100 that I just bought
call tmobile asap they will give you the code
Posted on Apr 02, 2008
samuraix
  • 203 Answers
SOURCE: alias sch u740 bad reception
hey, make sure that the simcard that you are using is supported by your celphone, the one that they called openline means all networks or simcards can be use with it.
Posted on Sep 30, 2009
odiebugs
  • 949 Answers
SOURCE: my display has blacked out the phone is working
Turn off the phone, and remove the battery for a few minutes.
Then replace the battery and power up the phone, if your display is still dead, you should go to the website of the MFG and contact them and tell them what the problem is, and they will probably give you a RMA,
see if you can find out how much the repair would be, If the phone is this old, it might not be worth it, and you should also be able to get a new contract and new phone from your carrier.
Posted on Feb 05, 2010
I used my Haier tv on cable service. I moved to rural area where there is no cable service. I tried to use my tv on an HD antenna, cannot get a signal. ???
You gotta try to reprogram your channels, but first you must have an external antenna to receive the signal. Follow your TV manual and set it to automatically reprogram it. It may take a long time since it will try to setup regular (analog), digital and cable channels (analog and digital as well). Depending on how far you are from the TV stations, you may also have to install a signal booster (amplifier) before attempting to reprogramm the channels, so you can get more channels without glitches. If you have internet you can also watch TV over it.
- For over-the-air TV - here you can enter your zipcode to see which channels are available in your area:
Which OTA HDTV Channels Can Get Over The Air OTA DVR Tablo
- For over-the-internet TV: This guide is very helpful.
How to Watch Live TV Online
Satellite is another good option. Dish Network or DirectTV are 2 good options for remote areas. I have never had satellite, so I can't precise with one is the best for you.
Gil
Jan 25, 2015 | Haier Televison & Video
What are rural areas
A rural area is an open swath of land that has few homes or other buildings, and not very many people.
A rural areas population density is very low.
Many people live in a city, or urban area. Their homes and businesses are located very close to one another.
Feb 13, 2014 | CARNI FUEL DEFINITION 8 FL OZ 250 Softgels
What antenna do you recommend wit the RCA 20F510TD
This tv has an analog tuner so you will need a digital-to-analog tuner set-top box (assuming you live in an area where most stations have been converted to digital TV broadcast). Whichever tuner you use, the recommended antenna will depend on where you live and how many tall objects are between you and the transmitters. Go to antennaweb.org or tvfool.com and type in your address. Antennaweb assumes an external antenna but is still very conservative in the channels it will identify as watchable in your area. Tvfool.com lists the channels by direction and the antenna type (by color) you will need to receive them. The color rating is based on how far the stations signal travels to reach your location. An amplifier can help you receive stations that are marginal to your location. (Digital signals are sufficient for the TV to tune them in or you get "no signal" messages.)
I hope this helps.
(I'm in a rural area with an external antenna with a signal splitter/amplifier. Antennaweb suggests I will only get the stations ~10 miles away. In fact I get the stations from there as well as the ones ~30 miles away.)
Sep 11, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
I have a unidenbc72xlt scanner--I live in a rural area and reception is terrible. when i get to city(about 25 miles away) it works good but at home is terrible--any solutions
Your ONLY solution is an external antenna. The best scanner is only as good as the antenna that feeds it. A discone would be the best, but a less-costly vertical would probably do a good job for you. The least costly, and least effective solution would be an indoor antenna - the ones enclosed in PVC pipe do a fair job. If you can't mount the antenna on your roof, a balcony or an attic will usually work fine. As a last resort, you can always set up a vertical inside a closet. eBay is a good source for scanner antennas, and you might also try www.ScannerMaster.com.
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Dec 30, 2009 | Radio Shack Pro-97 Handheld Scanner
Ihave a netbook Acer Aspire one D250-1116
haha same here and i have an acer aspire one too and i live in a VERY rural area people in the next town over haven't even heard of it. i heard you can get those things on ebay pretty cheap
Dec 15, 2009 | Acer Aspire One Netbook 8.9" Notebook
I live in a rural area and can't get a signal
That is a common problem. I have had that issue myself. Motorola's pull a better signal in a rural area than LG. I would see if you can do a return exchange for another like phone that is a Motorola. It's the way the phones are made that makes the signal strength different.
Nov 12, 2009 | LG enV3 VX9200 Cell Phone
Garmin Nuvi 760 loses satelite reception. Tried to reset to factory settings and still having problem.
You may need to buy an additional external GPS receiving antenna. I did for my 750.
Because we love our electronics so tiny, they use an internal antenna. The gold input on the back of it, is for an external antenna available for under $20 from ebay. I used it when I lost reception in NYC, and also in rural areas. The external one has q magnet on it, and you can put it on the roof and have the cord come in your window to the unit (better than arm out window!)
check here - where i bought mine
http://cgi.ebay.com/AMPLIFIED-GPS-ANTENNA-FOR-GARMIN-NUVI-760-750-770-780_W0QQitemZ220265873242QQihZ012QQcategoryZ73348QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
Enjoy, NGK
Sep 03, 2008 | Garmin GPS
My phone won't do anything.
Oh i had this same problem Call the verizon people and Tell them you problem. what happened to mine was there was a error in the system. but i still cant recive or send Picture messages>.<
May 29, 2008 | LG enV VX9900 Cellular Phone
Razr V# lost service after using external antenna
I have the same problem. Contacted 3rd party tech, take sharp pick or equal and there is supposedly a button in the very center of the antenna port of the phone. gently push the pick in the center of the jack and it will trip the switch. I tried it on my second damaged phone and it worked, so far.
Nov 24, 2007 | Motorola Mobility RAZR V3
Samsung SGH-A707 Cellular Phone Logo
41 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
