HP DV6917cl Pavilion laptop Quicklaunch lights will not turn off
HP Pavilion Laptop. Took it apart to check out the fan beucase it seemed to be overheating. Put it all back together and everything worked perfectly with the exception that the Quick Launch touch pad buttons would not turn off while the rest of the laptop was powered down. They stay on while either the battery is on or the charger. I am out of ideas. I double checked the ZIF cables to make sure they were inserted properly. I even pulled it all apart to make sure I didnt miss any cables or screws. I am going to try to put it back together again with the hopes that maybe it was a grounding issue and maybe one of the screws was misplaced. At this point though, I have no clue what the problem could be.
Like I said, the laptop is in pieces right now. All I have hooked up is the power module, the quicklaunch/power button pad and it is still saying on for whatever reason which probably means it is not a cable in backwards or something. At this point it is an inconvienance, but it is not my laptop, it is someone elses, so I would rather not have to return it with this problem.
Thanks for your help.
Also the computer turns on if you press the quick launch buttons.
  • 1 more comment
  • Aaron Fox
    Aaron Fox Feb 09, 2010
    Im not, its already off, the battery is pulled and the power cord is off. When I do want to shut it down, I hold the power button for 5 seconds. The hard drive is not installed so its not like windows will become corrupt or anything.
  • Aaron Fox
    Quote "...the ribbon (zif) cable itself was crushed and needed replacing.
    Inspect the cables."
    That was my thought too, after carefully inspecting the zif cables, I ordered 1 new one. The lanes of conductive metal were either missing or out of place. Not in any huge way, just the tips, but enough to be concerned. I should have the new one by the end of the week.
  • petertrast May 11, 2010
    Sounds like it is sleeping. How are you turning it off?
  • 4,806 Answers
From what i can remember with HP laptops there are two ribbon cables that rup up the left hand side of the laptop which both look the same. One to the power button the other to the LED's and hot keys on the keyboard bezel (plastic strip that runs above the keyboard)
You may have accidentally used the wrong cable in the wrong slot. Try reversing the cable. power on and see what happens. You can also try to switch ends to see if that helps.
Let me know if there is anything else.
Regards.
Posted on Feb 08, 2010
  • Lee Hodgson
    Lee Hodgson Feb 08, 2010
    Also, Check all connections on the motherboard, make sure the ribbon cables are the right way round and that they are pushed into place straight and clipped in tight. You may have to repossition the cables and mess with them to get it right.
    Good luck.
  • Lee Hodgson
    Lee Hodgson Feb 09, 2010
    Just a thought but i had a HP laptop once where it had a similar problem to yours. I found that the ribbon (zif) cable itself was crushed and needed replacing.
    Inspect the cables.
How to fix a hp m7750n cooling fan
Checking the Fan Turn on your Pavilion and close the display panel.Flip your laptop upside-down and place it on a clean, flat surface. Shine a flashlight into the vent on the bottom of the computer and look to see if the cooling fan is spinning.
http://smallbusiness.chron.com/check-cooling-fan-hp-pavilion-laptop-55670.html
Dec 29, 2016 | HP Computers & Internet
How do I access the fan on an HP Pavilion DV3 Laptop? I've taken it apart with the online guide available but that failed to access the cooling fan. Laptop is overheating and it's clearly the...
Honestly, try harder. If you've taken the thing apart, you're more than half way there. You probably just need to unscrew more stuff and pry more parts out.
Jul 22, 2011 | HP Pavilion Dv3-1075us Notebook
Laptop fan has a noisy and pc is shutdown after some time ..so can I replace the fan ? pavilion dv3-2175ee
How to Replace a HP Pavilion dv3 Fan?
1. Follow your laptop owner's manual and assembly guide carefully you can download this from HP web site as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, CD/DVD drive and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the HP Pavilion dv3 Fan Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and fan. Replace the screws, plug the HP Pavilion dv3 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new fan running and feel warm air blowing from the vent on the side of the laptop. A HP Pavilion dv3 Fan does not run continuously, so don't be concerned if the HP Pavilion dv3 Fan shuts off periodically.
Jan 10, 2011 | Computers & Internet
My Hp pavilion tx1320us notebook pc that ive had for a few years now had fallen asleep and the battery died before i could plug the charger in. When i go to turn it on it turns on and almost instantly...
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 21, 2010 | HP Pavilion TX1000Z Notebook PC
I have an hp pavilion dv4- 1430 us that won't turn on
I had the same problem with my hp pavilion dv4 1430 and to fix it I just took out the battery and unplugged it from the power adapter and pushed the power button and waited for a few minutes I put it all back together and started it up and the screen turns right back on.
Jan 09, 2010 | HP Pavilion dv4-1140go Laptop
I have an HP dv6000 laptop computer, and, starting last week, the laptop acts like it's turning on (all the lights illuminate, fan starts for a second) but nothing on the screen, and then the laptop turns...
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Dec 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Insect buzzing noise.
If you feel the that the HDD or the fan is not making the insect buzzing noise then you maybe right it is the RAM... Open the ram slot and check how many RAMS are in there if there are two then remove the top RAM and keep it aside and start the system to check if the other RAM is making the noise...If there is no sound then check the same RAM which is in the system in the other slot and check if you are getting the noise...Then remove the RAM and then place in the RAM that was kept outside to check if the same happens...If the same happens at a particular slot then the slot is the problem and not the RAM....If one RAM is making a problem then you need to contact HP for the RAM....Please contact me if you need any guidance further down from here
Aug 18, 2009 | HP Pavilion dv9000z Notebook
My HP Pavilion dv6000 won't turn on
if no one led blink and it show no power then remove battery then refix it.
Jan 20, 2009 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
273 people viewed this question
David Payne
David Payne
