Question about Kenmore Refrigerators
Water not supply to make ice - Kenmore Refrigerators
  • 572 Answers
Check if dispender works. if it does check valve of make sure icemaker isnt turned off. id dispenser doesnt work check ur water filter, valve and water supply
Posted on Feb 08, 2010
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
Automatic ice maker stopped working, Checked water supply to back of freezer, and the water supply is on. Arm on ice maker seems to be in correct position. there is no water in ice maker. can feel the...
Assuming you have active water supply to unit, either water valve or ice maker is bad. If Ice Maker is sending power to valve during Ice cycle, then valve is bad. If no power to valve during Ice cycle, then ice maker is bad.
Sep 11, 2017 | Amana ARB2557CSR / ARB2557CSL Bottom...
My ice maker has stop working .mod FRT21TNGD3/FRIGIDAIRE
First need to determine water supply. Water filter and or inlet screen fouled? I know this is assuming the water supply is open..
Check the ice level bar to be sure it is in the correct position for making ice. If it is incorrect poition, the ice maker "thinks" the ice bin is full. I would start there with the water supply though. Most likely...
Jul 21, 2010 | Frigidaire Refrigerators
Leak on the ice maker water supply
Good day,
The house water supply is connected to a dual water valve on the bottom rear of the machine. It splits there going to the ice maker and water in the door.
If the ice maker side is feeding water to the ice maker even though the ice maker is in the off position means the diaphragm in the valve is leaking and must be replaced. Very common problem.
Apr 11, 2010 | Refrigerators
Our ice machine does not make full ice cubes. they are small and not complete, they are full of holes.
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not making ice. Water is in the supply
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Refrigerators
Water supply tube keeps freezing off water supply.
its hard to tell but most likely the valve is not closing all the way. but it could be the ice maker calling for too much.... www.whirlpoolpartssurplus.com
Jun 23, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker only makes cubes. It will not make crushed ice.
Hi
Kindly check it could be because of following reasons :
  • Freezer may not be cold enough.
    Temperature must be 5 degrees (Fahrenheit) or colder to work properly.
  • Normal ice making capacity.
    The ice maker will produce between 2.5 to 4.0 pounds of ice a day depending on your model. Side-by-side models come with a large ice bucket and it may take up to three days to fill this container.
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
    Please feel free to contact for further assistance
    Thanks
    Rylee
  • Jan 24, 2009 | Maytag MSD2651 HE Side by Side...
    The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
    Hello jitkagardner,
    Welcome
    You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
    How old is the fridge?
    When have you last changed the water filter.
    Should be down below at the front grille!
    Try these tasks!
    If the ice maker is not producing ice or not enough ice
    Refrigerator connected to a water supply and the supply
    shutoff valve turned on? Connect refrigerator to water
    supply and turn water shutoff valve fully open.
    • Kink in the water source line? A kink in the line can reduce
    water flow. Straighten the water source line.
    • Ice maker turned on? Make sure wire shutoff arm or switch
    (depending on model) is in the ON position.
    • New installation? Wait 24 hours after ice maker installation
    for ice production to begin. Wait 72 hours for full ice
    production.
    • Freezer door closed completely? Firmly close the freezer
    compartment door. If the freezer compartment door will not
    close all the way, see "The doors will not close completely."
    • Large amount of ice recently removed? Allow 24 hours for
    ice maker to produce more ice.
    • Ice cube jammed in the ice maker ejector arm?
    Remove ice from the ejector arm with a plastic utensil.
    • Water filter installed on the refrigerator? Remove filter and
    operate ice maker. If ice volume improves, then the filter may
    be clogged or incorrectly installed. Replace filter or reinstall it
    correctly.
    • Reverse osmosis water filtration system connected to
    your cold water supply? This can decrease water pressure.
    Let me know how it goes!
    Huuum
    Please remember to leave a rating!
    Oct 21, 2008 | Refrigerators
    Side by side refrigerator
    The ice maker is not producing ice or not enough ice
    production.
    OR
    The water dispenser will not operate properly
     Freezer door closed completely? Close the door firmly. If it
    does not close completely, see “The doors will not close
    completely.”
     Is the water pressure at least 30 psi? The water pressure to
    the home determines the flow from the dispenser. See “Water
    Supply Requirements.”
     Kink in the home water source line? Straighten the water
    source line.
     New installation? Flush and fill the water system.
     Water filter installed on the refrigerator? The filter may be
     Is a reverse osmosis water filtration system connected to
    GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
    Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
    Refrigerators Logo
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    ka4iup
    ka4iup
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
