Question about Bissell 1631 PowerSteamer ProHeat Canister Vacuum
Need motor where could I find one and how much
    Problem Solver:
  • 6 Answers
Try VacPartsWarehouse.com they sell many parts for carpet cleaners and vacuums.
Posted on Feb 08, 2010
Need to replace the motor on my Hoover Linx, as everything else has been replaced and it is still VERY loud, and a new motor is cheaper than a new vac. What motor do I need to get?
Julie,
You need to find the model number of your vacuum and then you should be able to just Google the model number and find a website where you could order the motor. If you put the model number in, it did not come through with your question.
Jul 27, 2015 | Vacuums
H3000 Motor becomes very hot during use
Over heating on a floormate is cuased by obstructions or a clogged up filter. Try running it without the recovery tank. If it doesn't over heat you need to check for obstructions in the nozzle and the tube leading up to the recovery tank. if that is all clear, a new filter should fix it.
If the machine over heats without the recovery tank on it, you might be right. Hoover only sells motor assemblies, not just the brushes. I have never seen them used enough to need new motor brushes simply because of wear. If the brushes are worn down completely, there is probably a short in the motor.
Let me know if this helps.
Dec 31, 2012 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
I have a older m&s system central vac model av625 one motor quit the brushes are gone are parts available
You will need a new motor, not brushes, as the worn motor will tear through new brushes. Search online for the M&S motor replacement and you will see helpful sites that will provide the replacement motor. Replacing the motor is not difficult. Consider replacing both motors as the second motor will go out in the near future.
Jan 10, 2011 | M&S Systems Bagless Central Vacuum
Hello can you help me please? I have a Kirby G4 vacuum cleaner, It did work ok until it started to give off burning smell and lots of sparks from the brushes. I have changed these brushes, the motor still...
Some debris, even sand or dirt, probably got into the motor, causing damage to the armature. If this is the case, you will need to replace the motor. The burning smell from the motor is generally a sure sign of a bad motor.
Jan 02, 2011 | Kirby G4 Bagged Upright Vacuum
Dyson dc14 Animal motor brush replacement
By the time the brushes are shot, so is the armature. You need a motor.
Oct 24, 2009 | Dyson DC14 All floors Bagless Upright...
Need to replace motor on a Simplicity upright vacuum and need help with the wiring the new motor. New motor is different from old one.
You might not have the right motor. Take the old one with you because it should go right back in as easy it was to remove.
Aug 22, 2009 | Vacuums
Model Oreck 2600HH- need schematic
white to motor terminal,black to other motor terminal,green is always ground to housing there is a small terminal tucked away its s small spot for the lights
Feb 01, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Shopvac motor not working
Then the motor brushes may be worn, or a winding is open circuit. Sears is pretty good at replacement parts, and they probably can supply just the motor assembly.
Jul 26, 2008 | Vacuums
Bissell 1631 PowerSteamer ProHeat Canister Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
