Question about Refrigerators
The light is out in fridge side i replaced the bulb but still no light. GE SIDE BY SIDE REFrigerator model #TFX25JRYD
  • 572 Answers
Check the door switch. sometimes socket corrodes
Posted on Feb 08, 2010
Testimonial: "this worked really well thank you for your help"
How to replace the upper light bulb on my ref
Here ya go, the manual. Most fridge light bulbs are easy and quick to swap out. If it's covered by a clear cover, just remove cover and unscrew bulb. General Electric Side By Side Refrigerator Specification Sheet...
Nov 25, 2014 | GE Refrigerators
Fridge light does not work.
Some appliances have electrical schematics on the back of the fridge, some are hidden behind rear cover. Wire,Switch or fuse..not much else it could be.
Aug 24, 2012 | GE Refrigerators
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
A side by side GE refrigerator with a loud hum
Hello Kchoffman73,
It sems we developed the same problem.
The hum seems to be coming from the bottom rear of the
fridge.
we have a GE side-by-side model TFX25JR.
The fridge is about 12 years old.
Whats the status of your fridge ? Did it ever stop
humming ? Did you replace or repair it ?
Does it still work ?
Thanks
Sep 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
GE side by side refrigerator model GSH25KGREWW
You said that the control board on rear of your refrigerator was replaced and there is still nothing happening? You do need to check the power behind the refrigerator to make sure there is power, yes.When did the control board get replaced and was it new?. Sea Breeze.
May 28, 2009 | GE GSH25KGRWW Side by Side Refrigerator
How to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
Jan 01, 2009 | GE PSW26SGRSS Side by Side Refrigerator
Fridge and Freezer not cold, compressor not coming on
these are 2 different things.check the light switch. also check cold-control, defrost timer, relay on compressor.
May 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Light bulb replacementR
A fridge light bulb is usually a 40 watt appliance bulb with a screw base. It is heavy duty to last in the temperature. If it is not easily accesible to unscrew and replace, there may be plastic cover to unsnap.
Dec 27, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
