Question about Kitchen Ranges
My oven will not turn on and is flashing f9 - Kitchen Ranges
  • 149 Answers
F9 Door lock safety circuit on power relay board sensed Replace power relay board
Posted on Mar 27, 2010
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Oven not working
F9 Door Latch Error Check latch and latch circuit
F9 Door Lock Warning Check door lock circuit or Replace Clock
F9 Program with door circuit Check wiring
4 different brands of stove indicate an issue with the door lock circuit. Hunt down the the tech manual for your machine on my youtube channel video
May 05, 2013 | Ovens
Frigidaire smooth top electric range flashes f9 after cleaning
The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted.
Test switches and if there is nothing wrong then replace the EOC.
What is the model number?
Nov 28, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
I was baking at 350degrees. My oven turned itself off and the error code F9-3 is flashing. please assist if abe.
The F9-3 error code means that either of the two oven self clean latches is stuck so ya need to check and see in both ovens if their is something from obstructing the lacth
if you also get a F9-4 that would mean its just the lower oven
a F9-5 would be just the upper oven
but for the F9-3 it could be either oven
Aug 28, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Set oven to clean, get flashing door indicator lig...
If this is an Electrolux oven then F9 relates to micro-processor resets itself.To get this to reset fully its reccomended that you disconnect the unit from the electric supply and then reconnect then retry.
Hope this helps
May 10, 2010 | Ovens
F9 Flashing on Frigidaire 30" range
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Dec 31, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Oven door locked, F9 indicator signal
F9 has to do with the door lock/latch monitoring switch, i would try to remove the oven for mthe counter andremove the back panel, in the approximate hieght levle of hte top of the lower oven mounted to the right side( standing behind) unit youll find a small lacth / motor assy, that drivesthe self clean latch, WITH POWER TURNED OFF> i wouldlook closely at the switch mounted to the assembly make sure its not out of line , (perhaps twiste doff to the side, not making contact, or something else real obvious.. definalty related ti a faulty read of that switch .chances are it got 2 hot and distortred teh mounting and/or function of that part.. worth a try any way good luck!
Nov 27, 2008 | Kitchen Ranges
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Kitchen Ranges Logo
74 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
