Question about Kenmore 62882 Electric Dryer
80 series electric dryer has power but wont start. where are the fuses located?
  • 572 Answers
Check the back
Posted on Feb 08, 2010
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
Wont start, is there a fuse? and where is it
There's a thermal fuse located on the blower housing along with the cycling thermostat and is wired in series with the motor. This thermal fuse blows when the lint duct and vent are blocked or when the cycling thermostat is stuck closed or not cycling properly. Power to the motor is terminated and the dryer will not start once the thermal fuse blows and no dryer function works. Make sure the lint duct and vent are clear. Click on the link below for the detailed troubleshooting instructions but make sure first that the dryer is getting power.
Troubleshooting Whirlpool and Kenmore Dryers
Not Starting
Mar 09, 2011 | Whirlpool LER5636P Electric Dryer
Hello, I think the fuse has blown in my series 80, Kenmore electric dryer. Can you please tell me what it looks like and the location of it. Thank you.
It's a thermal fuse and it is white plastic about an inch and a half long. has 2 wires going to it,usually lt.blue, If you remove the back panel of the dryer it is located near the dryer exhaust above the high limit thermostat.
If the thermal fuse is blown the dryer will not run.
Hope this helps.
Dec 11, 2010 | Kenmore 62802 Electric Dryer
Kenmore 80 series dryer -dryer wont start on any cycle.cant locate fuse
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 28, 2010 | Kenmore Dryers
Kenmore 80 series electric dryer wont start
Push the button manually and see if the light goes off . If it does , then the problem is the thermal fuse (a white slim piece of plastic with 2 wires connected to it ) located on the blower housing beneath the drum .
Jul 22, 2009 | Dryers
Dryer not working
check your door switch and if that is good then check the fuse located on blower housing,it is white with a black strip down middle and has 2 wires that go to it.you can put 2 wires together and wrap with electrical tape plug dryer in and see if it starts
Mar 09, 2009 | Dryers
Kenmore 80 series Dryer: Door Light stays on and wont start
Mar 05, 2009 | Kenmore 800 7982 Dryer
Location of the thermal fuse on the kenmore gas dryer 80
Feb 03, 2009 | Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore 62882 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
