Question about Nintendo DS Console
DS won't power up after case replacement.
After I replaced the case on my DS all I get is a quick orange light when power is applied. Then when I press the power button the green light comes on for a sec.
I've reconnected all of the ribbon cables and tried a known good power supply and battery.
Please help.
  • 1 more comment
  • Romanpeters1 Jun 27, 2008
    I have the same thing, but with the case of there is also a little lightflash at the ribon at the corner left under.
  • lynbins Nov 09, 2008
    my DS will note power up after case replacment its completly dead no lights or anything
  • fixitpop Feb 10, 2009
    Replaced the case on my son's ds lite. Also replaced the top screen and ribbon cable. But when he turns it on, all he gets is a quick flash on the lower screen then nothing.
  • 691 Answers
If you have changed the bottom screen this can also happen because the screen is shorting out on the board, ensure you have put on an insulating pad like the original screen
Posted on Feb 14, 2009
FYI
I JUST DROPPED A NINTENDO DS
BLEW F2 FUSE
POWER LIGHT FLASHS ORANGE ON CHARGE FOR A SECOND BUT NO POWER UP
DID A JUMP PER ABOVE AND IT WORKED LIKE A CHARM
http://kevinhaag.ca/2008/02/19/fix-a-nintendo-ds-that-wont-power-on-tutorial/
or
http://m3wiki.com/index.php?title=Nintendo_DS_Lite_:_Repair_a_broken_console_(blown_fuse)
Posted on Sep 03, 2008
Not sure if you want to do this but i had sorta the same problem.. the problem was i was trying to fix my sound problem , i ended up putting the battery the WRONG way and didn't know what to do , it would just light for a sec and go out..
found out what was wrong , i blew a tiny fuse on the circuit board, i set my multimeter to ohms and tested all the fuses(tiny) for continuity and found one with no continuity so i jumped it using wire (connected the 2 points of the fuse together) now it works like a charm.. never did fix the sound.. try checking for blown fuses.. might be your problem..
Posted on Jul 17, 2008
  • 61 Answers
If the screen flashes on then off, like a flash from a camera, it's the top lcd screen, even a tiny rip, crease in the ribbon will do this
Posted on Jul 18, 2008
  • 33 Answers
Umm well dose it just turn off if so there is a ribbon camble with a broken cord in it so you might have 2 replace it sorry but i dont kno wat ribbon cable
Posted on Feb 23, 2008
When charging DS lite the light stays orange
The issue is not with the fuses or with the battery. That end is working properly if the light stays a constant orange. The issue is with the other end, how the system powers on. Check the power slider (on mother board) or the L2 inductor (located below the slider). Chances are the tab on the slider has broken off or the L2 slider broke off from the motherboard.
Jul 06, 2013 | Nintendo DS Lite Console
I have a ds lite that works ok but when i put the charger on i get no orange light ?
you could get a new charger,or maybe the light is broken,or there might be something in the ds blocking the light making it so it won't light up.
Jul 19, 2011 | Nintendo DS Lite Console
Nintendo DS Lite battery and power problems
take it to best buy or where you bought it and they might tell you whats wrong if they dont go to support.nintendo.com and put it in repair and it will cost $50-$90
May 22, 2009 | Nintendo DS Lite Console
Will not turn on
Since you've already replaced the battery it could be a fuse issue.
The DSLite has 2 fuses and either one could be the cause of the problem.
To fix this problem it has to be opened and repaired.
Apr 13, 2009 | Nintendo DS Lite Console
Ds will not come on.
how to fix the top screen of the ds light which shows a sky blue back ground
Apr 08, 2009 | Nintendo DS Lite Console
Nintendo ds wont charge
cheekiemunke,
First of all, your DS Lite is charging both ways.....with power on and without power on.
You have for almost 99% sure a blown fuse F2 on the systemboard.
If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash.
So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
Regards
John
Nov 27, 2008 | Nintendo DS Console
Nintendo ds
There are a couple of fuses inside the ds and one of them is right up next to where the charger plugs in try to replace it. It is a little flat black piece with solder on each end and it should have a number on it you with need to replace it with the same number fuse.
Oct 03, 2007 | Nintendo DS Console
Nintendo DS Console Logo
921 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
