The display does not expand the entire monitor? i have a 25" monnitor and the dispaly is only using 15"?
  • 742 Answers
You need to setup your monitor for full display. Look at the button in your monitor and press "Auto/Set" (or something similar) then it will start to display as desired. Actually, your 25" monitor has a built-in option to display in several aspect ratio. Please choose a ratio that will fill up the entire screen.
Another one restriction here is your video cards. Some video cards limit display size and resolution.
Posted on Feb 09, 2010
THE MONITOR I USE FOR MY COMPUTER IS A SAMSUNG 50" PROJECTION TV THAT CAN BE USED WITH CABLE,PC, HDMI,WISELINK,AND SOMETING ELSE . MY PROBLEM IS I HAVE A MATROX MULTI MONITER WITH G55+ MDHA32DB NUMBER ON...
What OS are you running? Can you access your OS in Safe Mode ?
If so: access the Device Manager (by right-clicking on My Computer, selecting Manage from the available options. Then select Device Manager on the right). Uninstall your Matrox display card. This forces your computer to re-install it, with default settings when your computer restarts.
On my Windows 8 system:
(Window key + P) bring up a menu that lets me select whether I want to use my Primary Display only, have things Duplicated over both displays, have things Extended over both displays, or use my External Display only.
Holding in the Windows key, then pressing the P key once - cycles to the next available option. Letting both keys go, selects that option.
Keep doing this until the display that you want to use initialises. You should then be able to make the changes to the settings that you want to.
Feb 13, 2013 | Dell Dimension 4600 PC Desktop
External monnitor
Plug in the external monitor to the monitor port. Open display properties and set the display to use either 2 monitors (internal and external) pr just to use the external monitor. If just using the external monitor, you can usually us the FN key and one of the function keys to switch to the external monitor.
Aug 21, 2012 | Toshiba Computers & Internet
Monitor dispaly picture for 3 to 5 second then display gone
From the description one of the inverter transformers have failed, located on the power supply/inverter board.
May 21, 2012 | Samsung SyncMaster 510N (Silver) 15 inch...
Computer on but screen does not come on
Try using an external monnitor. If you can see the display the issue is likely the screen or the lcd ribbon. If you cannot see the display using an external monitor, then you have a blown graphic chip. You either need to replace the motherboard or reflow the graphic chip. I am no fan of BGA reflows. The don't last beyond 90days.
Good Luck
Nov 24, 2009 | Dell Latitude D610 Notebook
My macnotebook pro didnot dispaly anyhting but I can hear when the computer starts
check display on external monitor.
if it shows display on external then it means that there is the problem in internal lcd of the notebook.
Nov 04, 2009 | Apple Customized 15 MacBook Pro Notebook...
No display
First open cpu cover then refix RAM memory.
Then power up then press F8 key then enter in enable vga mode go to control panel ->dispaly ->settings change screen resolution to 1024*768 .
If you still not get display check monitor to cpu vga port connection reconnect into it.
Aslo pull out cmos cell for 15 minutes so all bios settings are defaults then check .
you can find cmos cell on motherbord chip set in cpu.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 24, 2009 | Acer 22" X223w LCD Monitor
Window does not expand to entire moniter
right click mouse
select Graphic Properties
select Display Settings
select Display Expansion
select Full Screen (No Border)
Mar 24, 2009 | Samsung SyncMaster 205BW LCD Monitor
Monitor dispaly problem
I think this problem appear video o/p section.Dry solder Pl. solder video output section
Jun 01, 2008 | LG Computers & Internet
Phillips monitor 150b3 no dispaly just power on
monitor on position and display show "AGING..."
plz solution
urjant
thanx
Feb 26, 2008 | Philips 150B3T 15" Flat Panel LCD Monitor
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
