Panasonic Flat screen TV has split screen. TV is about 4 years old but bolted to the wall. The dog stepped on the remote to cause the problem. Unplugeed TY for an hour and tried to re-set, but do not know where the re-set button is. Pushed a clear botton near the start button. Nothing happened. HELP!!!
    President:
  • 1,944 Answers
If you keep the TV disconnected from the power long enough, the TV should hard reset.
Posted on Feb 22, 2008
  • Damen Wong
    Damen Wong Feb 22, 2008
    Try leaving it unplugged for a few hours. Also, what exactly do you mean split screen?
One year old Panasonic Split system only blowing air
The compressor may possibly still be working but has no more freon. Ths may be caused by a leak.
Nov 16, 2013 | Panasonic Single Split Wall Mounted Air...
I have a Panasonic 46" flat screen plasma tv that will stay on for as long as you want, but when turned off, will not come back on for hours
If the set is a few years old you might want to look at the caps in the power supply--not unusual for them to be puffed up and hence cause issues like this.
May 26, 2012 | Panasonic TH-46PZ80B 46 in. Plasma TV
What is the remote learning code for my 32" TV
Mounting an LCD (Liquid Crystal Display) TV on the wall may seem a bit overwhelming at first; but it's not that difficult. With a few simple tools, a proper mounting kit and a helper, the job will be a breeze. With a little bit of patience and an hour or two, your LCD TV will look great. Follow these steps to learn how to mount an LCD TV on the wall.
Things You'll Need:
LCD TV
Mounting kit
Tools
Step 1
Find the best spot on the wall to mount the LCD screen. Think about how much room you may want on that wall, especially if you plan on mounting speakers, too. You could hang a poster or picture relative to the size of the television on the wall to see if you like the placement.
Step 2
Pick a mounting kit. You can purchase mounting kits online (see Resources below) along with many other sites. Look to make sure the kit and TV are VESA compatible so that you have standard measurements and quick, easy attachment during the mounting process.
Step 3
You may already have tools needed to mount the TV. You'll need a set of screwdrivers, a socket set, a saw capable of cutting into drywall, a drill and a measuring tape. Having a stud finder with a built-in level is also great to pinpoint the exact location of the stud. The stud finder will be useful if you'll be running wires through the wall.
Step 4
Get the location for the TV picked out. Check near the bottom of the wall to see if the area you plan on using to run the wires is free of obstructions. Using the stud finder for this will make it easy.
Step 5
Find the studs. You should use at least one stud when mounting the LCD screen to make sure that the mounting bolts are driven into something solid that will support the weight of the TV and the mounting bracket. Using two studs is ideal for mounting larger TV's, those with screens larger than 37 inches. Use a pencil to mark the drill holes for the anchors and stud location.
Step 6
Secure the mounting rails to the back of the LCD screen. Double check them for proper fit. Make sure that they're hidden behind the body of the television for a finished look.
Step 7
Cut the hole for the wires to come through by using a drywall saw. The easiest way is to pull them out at the electrical box. This avoids having to go into the basement, closet or otherwise. You can purchase a wall box at your local home improvement store to place in the exit hole of the wires.
Step 8
Drill the holes for the bolt anchors in the locations that you measured and marked previously. Place the bolt anchors into the holes and tap them in with a hammer.
Step 9
Secure the wall mount to the wall. You'll need a socket wrench to ensure that the mounting bolts get snugged down tightly to the anchors. Use a level to make sure you've done an even job.
Step 10
Grab a friend or family member to help you lift the LCD screen onto the mount. Make sure it's locked down tightly and the screen is set to go.
Hope this helps and Good luck
Sep 25, 2011 | Televison & Video
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
May 29, 2009 | Panasonic PT-50LC14 Television
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Picture and Sound Cuts Out When Moved
we repaire lcds 01455848477 cntact us you must have a sort on the powerbourd and give it time it will go
Mar 01, 2009 | Panasonic TH-50PX75U Plasma HDTV
Panasonic DMR-ES20
For the remote to work, make sure "video" is selected (instead of "tv"). It's the little button on the remote under the red button at the top that turns on the TV ("TV/Video")
As for the split screen, I've had that happen numerous times (when I lose power or revert to default settings). YOu have to go to Setup, Display, and select 4:3.
I hope I have helped you. I'm having other problems - with the audio. Some channels have no audio (maybe 3 or 4) and 2 channels are in SPANISH!!! (??) Weird that it's not uniform. I even tried reverting to default settings (and got that split screen!), but didn't help. It "jumped" a few times to the input type screen. I'm thinking some chip got fried or something. I've had it almost 2 years, and guess that's the "built-in" obsolescence!! :-)
Sep 26, 2007 | Panasonic DMR-ES20EG DVD Recorder
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
