Question about HP 1040 Plain Paper Inkjet Fax
HP fax/scanner/printer I used a 30V DC power supply for my HP fax/scanner/printer, then realised that the power supply should be around 18V DC. Since then, the fax and scanner add an orange background color to all documents. I guess, I must have damaged some electronic parts of the scanner/fax. I am an electronics engineer and would like to fix it by myself (if possible). Any help on which part I should check and may be replace? Thanks in advance Martin
    Genius:
  • 2,120 Answers
Parts are probably not available except for modules.
I would say the scanner assy is toast.
Posted on Sep 01, 2008
I have a clunking noise on a hp 5035 printer
its the drive gears. I've repaired a few of these, you have to take off the power supply, DC controller, main motor, and strip down the drive assembly to replace about 5 gears - total time to repair is about n hour if you know what you're doing. I wouldn't attempt it if you're not a copier tech.
Apr 20, 2012 | HP® LaserJet M5035 MFP Laser...
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
My Lexmark X9350 All-in-One doesn't turn on.
Actually, the printer's power cord should be plugged in to a power source having 110-220V output. The power supply (the black box behind the printer where the power cord is attached) converts that power to 30V. Basically, if your wall outlet has power output of 110-220V, you won't need a transformer to convert that to 30V. That's the job of the printer's power supply. Hope this helps. If you need more clarification, place a comment so I can get back to it. Thanks.
Apr 16, 2010 | Lexmark X9350 All-In-One InkJet Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Printer d5060
1. plug something else into the plug to make sure it is live.
2. make sure the power cable is firmly inserted into the back of the machine.
3. make sure the power switch is in the on position.
If this doesn't solve the problem then the machine needs a high voltage power supply or a DC controller. Good Luck!
Sep 15, 2008 | HP PJ9120 Fax, Copier, Printer, Scanner,...
Copier not working
Dear sir, I have hp all-in one printer, copier, scanner Model. While suppled to DC 18V power supply Printer disply shows First massege "Inisillation" later Shows Error C402. I have contact local repairer who had told me to replace logic card of printer which costing is approx. 2/3 of new one. Kindlyhelp me in this matter & if Possible Let me now can the error C402 is due to logic fault ? Regards, B.A.Thakker.
Dec 01, 2007 | HP PSC 750 All-In-One InkJet Printer
Errors
Hi Jean, The issue can occure only when the HP printer is not gettting enough power supply or the scanner bulb is not getting heated up properly.. You can isolate the issue by directly connecting the printer to wall jack and powerup the printer and try to make a copy so that we can check the copy function as the copy,scannig and FAX use the same scanner bulb to performe all functions.. If the copy does'nt work try to lift the scanner lid and check if the scanner bulb is lit and the scanner machinasium is moving fine or not .. lift the lid and press scan button to check the functionality. If the printer is connected to a surge protector or power strip this will some time fail to provide the required power supply to the printer so connect it to wall outlet and check with the issue.. There is also a FIRMWARE UPDATE RELEASED BY HP to fix the some of the scanner failure and receving faxes issue with HP 6110 All-in-one Here is the weblink to download and install the firmware update just click on the link to open the download page and then click on download and select save to save the patch to computer and run it to install the update make sure that the printer is connected and turn on while installing the patch The link to download: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14700-3&lc=en&cc=us&dlc=en&product=79477&os=228&lang=en Hope this will fix the issue.. If the issue is with the scanner failure message try the instruction in the below weblink: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00787271&cc=us&lc=en&dlc=en&product=79477&dlc=en&lang=en Wish you success Jean Regards, Barret
Sep 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
OfficeJet 7310 FAX issue
Did anything happen prior to the issue? It almost sounds as if the DC controller (main board) has gone bad. What happens if you try to make a copy on it?
May 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP 1040 Plain Paper Inkjet Fax Logo
82 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
