Question about Exercise & Fitness
How do i fix my pro form 485 pi i put batteries lights up but won't show speed and kms
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Pro form 995 motor won't turn on
Dear Sir:
You must do the following:
1) You must check the receptacle wall, for 115volts AC,60hz
2) If Not voltage 115 Vac, check breaker or fuse from the Panel( Main) or Sub-Panel for that circuit.
3) If there are 115 Vac, so proceed with the wires of the plugs, retigh conection and see if the contact of the plug is clean or oxide, ( clean with ethilic alcohol 100%) .
4) Check the Main button if there Voltage use the VOM( Voltimeter) , after check the push button Start , clean this .
5) If not work, check the relais and clean with ethilic alcohol 100% in the Board Controller, after check the Breaker.
6) If everything is o.k now proceed to Start the Motor.
7) In short proceed Step by Step with the logic for Troubleshooting.
Please reply is everything is o.k or you need more assistance, Sincerely . God bless you.
E. Cuadra
Posted on Sep 05, 2011
AJIN G
  • 6694 Answers
SOURCE: pro form 380 treadmill speeds up without warning.
hi,
You have to check the Driver circuit board for the motor. There is motor control IGBT (Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will try to run without setting any value or witout pressing the start button. You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i ahve added the picture of IGBT for your refference.
ajin_g_90.jpg OK
Posted on Sep 11, 2011
I'm trying to install microsoft picture it on my pc (windows7) but a missing pi.exe keeps on apearing,how can I fix this
Free Guides to Fix PC Errors By PcTweaker Skip to content Leave a replypi.exe is part of Microsoft Picture It! 9 and developed by Microsoft Corporation according to the pi.exe
pi.exe Vendor and Version Informaiton : Product name : Microsoft Picture It! 9 Company : Microsoft Corporation Version : Md5 : 33be8a09351e58d22e5a3f35cff5ffa6 Why does my computer have the pi.exe wrong information cue? pi.exe is a file name that often appears in some error messages on the computer, if you frequently receive the error notifications which state that the specific program cannot be processed for the pi.exe file being corrupted or missing, you should consider to fix pi.exe error well for avoiding the related operation problems on your computer.When this file gets corrupted, missing or suddenly become invalid in the Windows system, you will immediately receive the pi.exe error message and you will need repair it as soon as possbile !
If you do not fix nengine.dll missing as soon as possible, you may face the problems below:
"System boot-up failure" "System file corrupt" "Slow system performance" "Blue Screen of Death errors" "White Screen of Death errors" Why need to Fix pi.exe Errors ? When the system has the pi.exe wrong information, it shows that the error has been affecting the Windows system's running stability. If this time not clearing up the pi.exe error quickly, the Windows registry can be easily damaged, and then the unsteady Windows registry will affect the normal use of other softwares or directly make them not work,and the whole Windows system can not be used normally.So, when the Windows system has the error message, we should hurry up to repair it well.How to fix the pi.exe error ? To fix pi.exe error is not that easy before,but now it is so easy ! Please download the Pctweaker software recommended by us, according to the following procedures. You can soon clear up the pi.exe error through a few simple procedures, and in the course the software will automatically repair your computer's Windows registry damage caused in normal operation.
Jul 23, 2014 | Computers & Internet
Pro-form 980, regardless what button I hit the speed goes to 12
1) test the speed sensor, for open or faulty, see the adjustment. Clean if and tight the connector very well
2) tight the ribbon cable for keypads , and clean it
3) replace batteries,and clean the contacts baterries very well
4) adjust the Reed swtich, test for open or faulty, clean it and tigh the connector very well see the diagram
5) Run the software calibration for troubleshooting, diagnose, and fix it.
Jan 22, 2013 | Proform 980 CS Treadmill
1985 vt1100 honda shadow sputters at cruising speed
My 86 vt1100 did the same thing ;and i did all the thing you did;what fix it was the float i raise it and that fix the problum.runs great hope that may help you
May 24, 2012 | Honda Motorcycles
My pro form 580 si won't reach max speed. Why is
Dear Sir:
Adjust the speed sensor very weel see the diagram attached, tigh the connector wires very well, and clean the s. sensor very well.
2) Run the software calibration for easy diagnose , fix it, and trouble.according with your manual instructions.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Apr 03, 2012 | Proform Exercise & Fitness
Convert -525 degrees into radain pi form
Here is some help
180deg is equivalent to Pi radians
Take some angle. Its measure in degrees is say x_deg, Its measure expressed in radians is x_rad.
The fraction of 180 deg that the angle represents is equal to the fraction of PI that this angle represents.
Conclusion: the ratio x_deg/ 180 deg must be equal to the ratio of x_rad/PI
x_deg/180 deg=x_rad/PI
Isolate X-rad in the above equation. Some will tell you to cross multiply.
x_rad=(Pi/180)*x_deg
Application: x_deg=-525 in radians?
x_rad= (PI/180)*(-525)=-(525/180)*PI
Keep the value (525/180) as a fraction reduced to its simplest form. The result is 35/12
Sep 26, 2011 | Casio FX-115ES Scientific Calculator
My Pro-form XP 185 U bicycle has a timing problem. It stops every 5 seconds, and you have to press the start button again. How do i fix this?
My pro form cardiocrosstrainer 800 has a timing, speed, and calarie
diplay problem. It does not work. How do i fix the problem with on the console display.
Jan 27, 2010 | Proform Cycling
E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Sep 28, 2009 | Exercise & Fitness
Exercise & Fitness Logo
99 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
