Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Says bulb has to be replace.
Get message on screen that says bulb needs to be replaced but bulb is less then a year old. plus tv has been shuting off and saying that bulb is overheated.. checked intake and outtake both clear.
    Champion:
  • 206 Answers
If your Tv is less than a year old you want to get ahold of Mithubisi NOW! There are two upgrades if you can call them that that adress the overheating and blocked airflow, And if the lamp needs replaced I'm sure you would rather have Mitshubishi pay for the 350.00 lamp than you
Posted on Feb 22, 2008
TV programs filmed after sunset need to be brighter
Old technology. Clean the optics and replace the bulb. Better off buying a new LED flatscreen in 4K Ultra HD :>)
Mar 07, 2018 | Toshiba 56HM66 56" Projection HDTV
Does the gaggia titanium have a grinder sensor? Can anybody tell me where it is? I have the "grinder blocked" message. I've cleaned the grinder, Shute and doser door, but I still have the...
Hi...Grinder blocked message is ..when you make coffee there is no current going into the grinder. In other words the grinder motor is blown(coil windings in the motor is blown). You have to replace the motor. The problem is common with Gaggia, Talea, Odea coffee machines. hope your machine is less than 2 years old to get fix under warranty.
Apr 10, 2012 | Gaggia Titanium Espresso Machine
I have a samsung projection tv and it is starting to go dark on the screen could this be the bulb
There is a possibility it might be the lamp, if you've never replaced it on the TV it's better you replace it. It could also be a ballast issue, it depends of how old the TV is. for example if the TV is less than a year old, that would definitely not be your bulb. Bulb for Samsung are around 110 dlls and the ballast around 80 dlls, www.discount-merchant.com?Click=48427 they have very good deals. If you're going to purchase the lamp, remember that it's best if you go with the original Philips lamp, otherwise it won't last that ling.
Nov 03, 2009 | Samsung Televison & Video
TV wont power on but green light indicates power on
No,it ur backlihght video inverter board is dead,need a new board.
Sep 27, 2009 | Philips 50PFP5332D 50 in. Plasma...
KDF-E60A20, picture and sound go out then re-appear every 30 sec
Was it just the bulb or the complete lamp assembly? If it was just the bulb you need to handle it with latex gloves to avoid getting oils from your hands onto the lamp.
Sep 10, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Red light flashing while green light stays on
I have the same TV, your projection bulb has quit/failed.
A loud pop was heard and the picture has gone followed by a red led fault light clicking on and off.
if your tv is less than 1 year old, and you registered it with Toshiba, you could qualify for a free replacement.
otherwise expect to pay 200.00 for a new bulb from Toshiba.
only good thing is you can replace it yourself, only tool needed is a phillips screwdriver.
you can check EbaY for prices less than 175.00 to 150.00
i am on my 3rd bulb within 4 years....
good luck!
Aug 19, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Sony KDS-50A2000 screen is in green tint
My Sony KDS 50 A2000 is 17 months old. Its the 50 Inch SXRD projection model. About two weeks ago the screen developed a green tint with cannot be tuned out, then a few days later the message began to appear on the screen that the bulb was nearing the end of its life and must be replaced.
Fortunately I have the Circuit City extended warranty.
I called and within just a few days a serviceman came out and replaced the projection bulb.
The Result: No change in the picture, the green tint remains on all channels, so I'm awating the next service call. Under the service warranty they have the option to repair or replace this set. If indeed this is the light engine (optical block) which I suspect and its going to cost $1,000 or more I may be looking at a new set.
When it works this is a great TV, but I have had three Sonys now including two other standard CRT models and now this one joins them in the junk heap, the other two also bit the dust after just about two years. Is it time to give up on Sony?
I know they have a class action suit on a similar model for this same problem. Caveat emptor
Jul 31, 2008 | Sony KDS-50A2000 50" HDTV
LCD TV picture screen very dark
I have the same issues with my Westinghouse LCD set. I've found that going into the settings (using the TV remote) I can get it back to a bright picture by selecting 'restore factory settings'. It is aggravating and a pain, but I can correct it.
It only seems to do it on the analog stations, not the digital (HD) ones, so maybe it will go away after the conversion next year.
Hope this works for you.
Feb 18, 2008 | Televison & Video
Projection lamp shuting down
Confirm if this is happening during explosions screenshots or high white tones images. I noticed that my set goes black immediately after an explosion or during commercials (Essurance commercials for example). I'll have a technician tomorrow to replace the power board (another problem), but I'll also show him my observations to get his feedback about the blank screen...will let u know!!!
Aug 27, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
