Question about Abit IC7-MAX3 Motherboard
Green light lit but will not start, no fans running
  • 67 Answers
Without further knowledge of it's previous condition, I would say the power supply is bad. There are multiple rails of voltage in a power supply, while one may be functioning, a 2nd is not and therefore it will not pass its own pre-test and therefore will not function as a whole. I had the same exact description recently, I replaced my power supply and it was functioning perfectly. If there is another computer in the house with the same watt/voltage power supply, try swapping it out.. if the computer starts, the power supply is your problem.
Posted on Feb 08, 2010
Green light on my power supply stays lit after unplugging
Usually the light will time out after the capacitor has drained. Your machine is getting a bit old , your PSU may be the problem. If you plug it in and push the on/off button and it blinks, fans spin and shuts down, it's most likely the PSU. Look for a in-line fuse on the Motherboard, if blown, replace. Look at the motherboard closely for damaged components, capacitors, etc.
Jan 27, 2013 | HP Pavilion A820n (PP165AA) PC Desktop
Help please...my Dell desktop Inspiron 518 won't turn on at all.
First Option:Please Take a New Window .
Secon Option:This Falut is Hard.
Last Option:This Falut is Your Board The Board Is Shatig.
Jul 30, 2012 | Dell Computers & Internet
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Started making noise. found fan filter in rear plugged with dust. found noisy fan. It was very dirty. carefully cleaned it up and put 1 drop oil on bearing. Seems much quieter now. are fans replaceable?...
I think you did the right thing by just cleaning it. The fan is really there to help prevent the motor from overheating.
Overheating is typically the way breadmakers fail, so you've prolonged the life of yours by maybe another 5 years!
Light oil on the bearing and keeping the dust down is the right thing to do.
Well done.
Red and green lights will be simple diagnostics tell-tales. Both are lit - so no worries.
Feb 07, 2010 | Kitchen Appliances - Others
It makes three beeps and the fan will be running and the power light will be on no screen display when you leave it running and switch off and on it works fine
check out your memory ram, try to replace it and switch on again,..also check your cmos battery, if it is low, then replace a new one....last options are to check and change the processors..try it
Oct 28, 2009 | Computers & Internet
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Emachine 3240 possible power problem?
I would suggest try to swap the power supply out with another known good power supply.
I've seen where even though the light on the motherboard is lit, it is not getting enough power to start the machine up, especially if you have a higher end video card connected to it.
Jul 09, 2009 | E-Machines eMachines Desktop PC
Power Problem
It could be the power supply isn't getting enough current to run things. I'd start there.
Jun 21, 2008 | Dell Dimension 4600 PC Desktop
Abit IC7-MAX3 Motherboard Logo
117 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
