Question about Humax LD2060 20 in. EDTV-Ready LCD Television
We have Humax LD2060 with directv receiver installed. The TV will not power on. It is plugged in, faint screen like powered on, but no indicator light showing power on. Will not work manually or by remote.
  • 1 more comment
  • drentz8109 Feb 08, 2010
    Is there a way for us to check the fuse or capcitators?
    Can we check the fuse or capacitators ourselves? How do we do that?
    Thank you for your help. We will get it checked out by a pro. No sense messing it up!
    Bob
    President:
  • 2,923 Answers
There are some possible reasons why there's no power coming out. Could be a fuse on the Circuit Board or The Power Supply Capacitors are bad.
For this problem, it's better to have a local repair tech to check and repair it for you. If the problem is the fuse or capacitors, then it should not cost too much. But if the power supply board needs to be replaced, that might cost for about $150 up to $250 depending on the model of the phone and the availability of the board.
Good luck and have a great day!
Posted on Feb 08, 2010
  • Melvin Ramos
    Melvin Ramos Feb 08, 2010
    If you know the location of the capacitors and fuse, yes you could check it using a multi-meter. The value is listed on most capacitors, if you check the capacitors, the value that will appear on the multi-meter and on the capacitor should be the same.
    However, if you're not familiar with it, I would suggest not to do it. Because the TV or the board should be powered up while checking the capacitors in order for you to get the correct value.
    Now, if the value appeared on the multi-meter is different from the value on the capacitor itself, then the capacitor is bad. Because it's not giving the correct value.
    But if you're getting confused on which to check, that's the time you will need to get a second opinion from another local repair shop.
    Thank you!
What does code 576p indicate?
576p means 576 lines, progressive scan. 576 is number of visible lines on the UK system (and other nominally 625 line countries). The normal transmission system for these countries is 576i (interlaced scan), so I suspect that you are only seeing the 576p indication because there are no channels, and your TV is interpreting this as progressive scan.
The reason for no channels may be a poor signal from the aerial, or that the device (Humax or TV) has not been tuned. If you have power-saving enabled on the Humax, it will not pass on the aerial signal to the TV when the Humax is in standby. If this is the case, either turn power-saving off, or use a splitter to feed the aerial separately to the TV and Humax.
Oct 20, 2015 | Humax PVR9300T HD DVR
Could you please tell me how to reset my tv? I have a blue screen
What should I do if my TV screen turned black, blue, or gray? print.png Print try this.
Proceed with the troubleshooting steps below only if you're seeing:
  • Black, blue, or gray screen
  • "No Signal" message without the DIRECTV logo
Note: If your TV screen appears "frozen" or you're seeing wavy lines or overlapping images, try this.
Solution 1: Check that your TV is set on the right input
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number1_icon.png">Turn your TV and receiver off and back on.
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number2_icon.png">Using your DIRECTV remote control, press the TV Input button to cycle through TV inputs (Component, HDMI, etc) until you see a picture. If nothing happens when you press the button, try programming your DIRECTV remote to control your TV Input and try again.
Note: You can also try changing the TV Input using your TV remote.
[img border="0" alt="Image" src="http://www.directv.com/cms2/global/icons/sm_cl_blu__number3_icon.png">If you're still having issues, check the cable used to connect your receiver to your TV.
Still not seeing a clear picture?
Continue to Solution 2.
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/support/answer_center/tech_faq_images/img_screen_off_4.jpg">
Solution 2: Reset Your Receiver
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number1_icon.png">On some DIRECTV receivers there is a red reset button located inside the access card door on the front panel. Press it, then wait for your receiver to reboot.
Note: If you cannot locate the red reset button or your receiver does not have one, unplug the receiver's power cord from the electrical outlet, wait 15 seconds, and plug it back in. Then press the Power button on the front panel of your receiver and wait for your receiver to reboot.
could-please-tell-me-reset-tv-blue-i0x50p0fk40mg1d0uyxi2cma-5-0.jpg could-please-tell-me-reset-tv-blue-i0x50p0fk40mg1d0uyxi2cma-5-1.gif
May 12, 2014 | Vizio L37 Television
I no longer have directtv and would like to use the tv with cable. How do I hook it up? I can't seem to make it work with my basic cable package.
The LD2060 is built to receive only the DirecTV radio frequencies. You won't receive standard television or HD RF signals through the coaxial connector.
Jan 29, 2011 | Humax LD2060 20 in. EDTV-Ready LCD...
Humax 20" lu20-td2 tv just flickers use to flicker then come on now just flickers thank ernie
needs new capacitors if you look on mainboard it is 31 32 33 just fixed 2 with same problem
Aug 27, 2010 | Humax LD2060 20 in. EDTV-Ready LCD...
Philips DSR708 DirecTV DVR hangs up after power up
Is this a new issue that has shown up on the receiver? If so then you might have a bad hard drive in the receiver causing it to hang on boot up. Also these units require two inputs from the satellite antenna so that could be another possibility.
Nov 17, 2009 | Philips DSR708 DirecTV DTV Receiver /...
Need remote code
Humax codes are,1325,1565,1569 Ted10
Apr 16, 2009 | Humax LD2060 20 in. EDTV-Ready LCD...
Directv dvr will not power on. The record light
Unplug the DVR for about 20 minutes and then plug it back in. If that doesn't work its probably time to contact DTV for a replacement.
Mar 23, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Tivo Dtv
No, you need a regular directv receiver, or a directv w/ tivo receiver or a directv dvr.
Oct 03, 2007 | Tivo Humax® HUM-T2500Digital Video...
Humax LD2060 20 in. EDTV-Ready LCD Television Logo
77 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
